Cedarone Posted December 5, 2017 Share Posted December 5, 2017 HI, I purchased an immaculate 2004RT about a year ago with 10,600 miles on it. It has Metzler Marathons on it that came on the bike. They were in very good shape but now are in need of replacement. I have only put 4000 miles on the bike. It was like one minute there was tread on the front and the next it was gone. It is also wearing unevenly with the left side being more worn out. I have been told by a BMW friend that this is common with the 1150 RT's. Is this common? If so, is there anything that can be done to prevent this from happening? Looking for suggestions for a good replacement set of tires. Link to comment
ron c Posted December 5, 2017 Share Posted December 5, 2017 Tom, yes this is common on the 1150rt. I went through several sets of tires on my '04 RT where the left side wore much faster than the rest of the tire. Some will say it is because of the way you ride or that the crown on our roads are at fault or it is because left hand sweepers are longer than right hand sweepers thus faster tire wear on the left. I personally don't think any of these are the cause. I believe it is misalignment in the forks. Here is what I did to help my situation. After mounting a new tire leave the axle pinch bolts loose. Loosen the fork brace bolts. With the bike straight up and the bars in center position push the bike forward and bounce the front tire firmly into a solid wall several times. Then without moving the bars tighen all bolts. This helped reduce the left wear. It didn't completely solve the issue but it made it much better. Some time after that I went to Bridgestone T-30 GT tires. This also helped. Regards, Ron C. Link to comment
dirtrider Posted December 5, 2017 Share Posted December 5, 2017 (edited) HI, I purchased an immaculate 2004RT about a year ago with 10,600 miles on it. It has Metzler Marathons on it that came on the bike. They were in very good shape but now are in need of replacement. I have only put 4000 miles on the bike. It was like one minute there was tread on the front and the next it was gone. It is also wearing unevenly with the left side being more worn out. I have been told by a BMW friend that this is common with the 1150 RT's. Is this common? If so, is there anything that can be done to prevent this from happening? Looking for suggestions for a good replacement set of tires. Afternoon Cedarone Your 1150RT is a single track vehicle so, no matter what, the vehicle follows, the front tire. That also means that the only way a front tire can wear off center is if the part of the tire that is wearing is touching the pavement. It won't & can't wear way off center due to air friction. If you really want to know what is wearing that front tire then just get some help & lean the bike over until the part of the tire that is worn is flat on the ground (THAT is the lean angle that the bike was being ridden at to cause that tire wear). Depending of the lean-over angle that you determine in the above you can pretty well tell what you are doing to wear that front tire. If you normally ride down the road with the bike leaned over far enough to have the worn area be on the pavement then you would think you would notice that wouldn't you? As a rule, most off center front tire wear is caused by cornering & riding through curves. Again, lean the bike over until the part that is worn is flat on the ground, that is the lean angle that the bike was being ridden at to cause that tire wear. In most cases a rider rides L/H corners/turns a lot faster than the sharper R/H turns plus a L/H turn is also longer than a R/H turn. Most riders also tend to use the same lean angle for most corners & just adjust vehicle speed to keep the lean angle in their comfort zone. Start watching for this & you see that it is mostly true. Also, in countries that drive on the R/H side of the road L/H curves are longer than the comparable R/H curve due to needing to stay right of the center line. Road crown seldom figures into (noticeable) front tire wear as the road crown angle is so shallow that any road crown wear falls right on the edge of center tire wear. You will also find that most BMW 1150RT's have a slight PTTR (Pull To The Right) due to the vehicle weight not centered on the bike's center line (ride with no hands on the handle bars & you will usually see this trait) but again the slight counter steer needed to correct this won't cause a front tire wear off-center far enough to tell it from normal center wear (ie can't cause the 10°+ off center wear most complain about) Edited December 5, 2017 by dirtrider Link to comment
Cap Posted December 5, 2017 Share Posted December 5, 2017 It is also wearing unevenly with the left side being more worn out. One year my buddies and I spent a day riding from south to north along the Montana front range. We had a full day of leaning left into a fierce crosswind while riding more-or-less straight. At the end of the day, our tires were badly worn on the left side. Anyway for my 2004 RT, I use Michelin Pilot Road 4 GT front and back. I wear out two back tires for each new front tire. That's all long range, reasonably fast, touring on local highways and mountain roads. No commuting, minimal interstates. No doubt there are better choices for commuters, but for my mission, the PR4's are great. Link to comment
MarkAZ Posted December 6, 2017 Share Posted December 6, 2017 Another for the PR4GT's. I have them on mine & am very pleased with them. Link to comment
cat0020 Posted December 6, 2017 Share Posted December 6, 2017 Not uncommon to have uneven wear on front tires of motorcycles, especially a heavy motorcycle like the RT, if you apply the brakes aggressively (or even just regularly), combined with camber of road surface.. Link to comment
Craig G. Posted December 6, 2017 Share Posted December 6, 2017 Quote: "Also, in countries that drive on the R/H side of the road L/H curves are longer than the comparable R/H curve due to needing to stay right of the center line." I've often heard this and made me wonder what front tire wear looks like in the UK... sure enough, their front tires wear on the right side. http://www.cambriantyres.co.uk/motorcycle-tyre-wears-more-on-right-side/ Link to comment
Cedarone Posted December 7, 2017 Author Share Posted December 7, 2017 Thanks to all for the replies. I have never seen this on any of my other bikes and usually wear out two rears for every front or close to it. I was worried since my long time BMW riding friend had advised me that this happens on the 1150 RT. He has had a few but rides and prefers the GS to the RT. Link to comment
cat0020 Posted December 8, 2017 Share Posted December 8, 2017 AFAIK, excess wear on front tire occurs on all heavy bikes that rely on front braking. More pronounced on BMW since they carry more weight down low that bike feels lighter (to steer) than others. Link to comment
AndyS Posted December 8, 2017 Share Posted December 8, 2017 When I first got my 1150RT (for the first 35000 miles), we were running older generation tyres and I would get pretty much exactly 2 rears to one front. Since the likes of the Michelin PR2,3 and 4, I have been getting more wear from the back. So that leaves me with a dilemma. Do I change the front one early and have a nice feel to the bike, or do I do a staggered rear to front change. Well the dilemma is easily solved, because bikes always feel SO MUCH BETTER with new rubber, I change the front early to coincide with a rear. The new feel is worth the extra money for the kind of riding I do. BUT, if I were just running up and down the Motorway and doing a boring commute, I would stagger the tyre changes. In truth, if I were just running on the Motorway, I would probably get much more out of my rear tyre. Link to comment
cat0020 Posted December 8, 2017 Share Posted December 8, 2017 Or you could have two set of wheels/tires.. change them as you feel.. better yet... get some spare motorcycles... one for the spirited rides, one for commute and another for long distance touring. Link to comment
greiffster Posted December 8, 2017 Share Posted December 8, 2017 Quote: "Also, in countries that drive on the R/H side of the road L/H curves are longer than the comparable R/H curve due to needing to stay right of the center line." I've often heard this and made me wonder what front tire wear looks like in the UK... sure enough, their front tires wear on the right side. http://www.cambriantyres.co.uk/motorcycle-tyre-wears-more-on-right-side/ FWIW, My '03 1150RT showed very little difference regarding R/H and L/H tire wear. But, the problem I always have with sketches like in the above link is the scaling....... Here in the US, normal crown on roads is +/- 1.5% (or 2%). It looks like this when scaled correctly..... And when you blow up the front tire and look a the relative slope across the width of the tire, it's unimpressive. A couple of millimeters vertically across the width. When folks talk about uneven wear left to right and post pics, the wear is usually well up the side of the tire. Simply not caused by a 1.5% crown. Regarding the length of L/H curves (in the US) being longer than R/H. Ok, but how much..... A minimum radius curve for a design speed of 55mph is about 1200ft. If you assume a 90deg curve, than the traveled distance (about 1885ft) between the two lanes differs by about 19 feet. Or approximately 1%. I doubt you'd be able to visualize a 1% wear difference on either side of the tire. If you are seeing L/H tire wear noticeably more than the R/H side, and that wear is more than say 1/4" (really 1/8") vertically up the tire, you turn left harder and faster than you turn right. Link to comment
dirtrider Posted December 8, 2017 Share Posted December 8, 2017 Evening greiffster Regarding the length of L/H curves (in the US) being longer than R/H. Ok, but how much..... A minimum radius curve for a design speed of 55mph is about 1200ft. If you assume a 90deg curve, than the traveled distance (about 1885ft) between the two lanes differs by about 19 feet. Or approximately 1%. I doubt you'd be able to visualize a 1% wear difference on either side of the tire. Evening greiffster It really depends on lane position & aggressiveness. Remember that a rider can see much farther through most L/H curves so they tend to ride them faster & leaned over more. Link to comment
greiffster Posted December 8, 2017 Share Posted December 8, 2017 It really depends on lane position & aggressiveness. Remember that a rider can see much farther through most L/H curves so they tend to ride them faster & leaned over more. Indeed. My point was that the difference in length of the L/H versus R/H curves is mostly negligible as it relates to tire wear. Link to comment
cat0020 Posted December 10, 2017 Share Posted December 10, 2017 Keep in mind the turning radius difference between left vs right turns in different traffic pattern. In right side drive traffic pattern, the left turns will likely require twice the distance to complete the turn vs a simple right turn at a regular 4-way intersections. Twice a year, I head out on my uneven worn front tire bike and ride for one of these highway mergers for 30 min session of right turns just to even out the tire wear pattern a bit: Link to comment
greiffster Posted December 11, 2017 Share Posted December 11, 2017 In right side drive traffic pattern, the left turns will likely require twice the distance to complete the turn vs a simple right turn at a regular 4-way intersections. This one is bothersome to me as well. On paper the left turn is probably twice the distance of the right, at an intersection. But when you are riding/driving the L/H turn, don't you pull well out into the intersection before initiating the turn? I'm not sure the actual distances in the turn differ that much. BUT, even if the lengths do differ, is it really enough distance to result in noticeable wear? And like your photo above, won't a little bit of interstate driving balance things out? Either clover-leaf or diamond interchanges, it's almost always right turns on/off. Link to comment
dirtrider Posted December 11, 2017 Share Posted December 11, 2017 This one is bothersome to me as well. On paper the left turn is probably twice the distance of the right, at an intersection. But when you are riding/driving the L/H turn, don't you pull well out into the intersection before initiating the turn? I'm not sure the actual distances in the turn differ that much. BUT, even if the lengths do differ, is it really enough distance to result in noticeable wear? And like your photo above, won't a little bit of interstate driving balance things out? Either clover-leaf or diamond interchanges, it's almost always right turns on/off. Morning greiffster Some do, most don't-- Most just arc the L/H corner at a speed at a lean they feel comfortable with. (lot longer & a lot faster). The R/H corner is much sharper so the speed is way lower plus it usually doesn't get a constant arc a but change in lean throughout the corner. Link to comment
philbytx Posted December 12, 2017 Share Posted December 12, 2017 Mainly chip and seal here in the Hill Country of TX.......I find that I get the best wear out of Pirelli Angel GT's, which are quite fairly priced. Usually about 4/4.5k on the rears and 6.5/7k on the fronts with fairly aggressive riding. Always LH side of the fronts wears down first. I run 37 and 39 solo with 38 and 42 when 2up. Link to comment
eliastfk93 Posted December 13, 2017 Share Posted December 13, 2017 The trait is normal, I've experienced similar wear patterns on my rockster. But as mentioned before, I would highly recommend giving the pilot road 3 or 4's a try. To this day they're the best touring/commuting tire i've ever ridden on. They should last a good long while too. Link to comment
EffBee Posted December 14, 2017 Share Posted December 14, 2017 I'm not an engineer and I don't play one on TV. But this is what I've culled from years of reading about the subject of uneven tire wear. And if I'm full of bull, one of our resident smarter people (of which we're blessed with many) will tell me so. Gently, please. All of the advice above is excellent. However, no one thing is responsible for uneven tire wear. Instead, it is a combination of the above and how it takes place as you ride and corner. As Greiffster points out, a simple 1.5% road crown will not create the problems you've experienced. However, when you add the two sides together, you get 3% (we'll get to how that math works in a minute), and 3% can be a substantial contributor. For the sake of this discussion, let's assume the measurement of 1.5% so we have a constant to work with. And since it's probably better to work in degrees, let's just round it up to 2 degrees of road crown, or a summed difference of 4 degrees between the two sides. First, there's almost imperceptible differences in side-to-side tire wear when riding on a crowned road in a straight line. A bit more when braking, because the front tire deforms (compresses) some and thus exposes a larger portion of its side tread to the 2 degrees of road crown that exists (plus there's a microscopic amount of side slip due to the road crown), but we're splitting hairs. Uneven front tread wear comes from cornering and, if you're a bit of a trail braker, from that, too. But for this explanation, let's work on the cornering. Let's assume a cornering angle of 30 degrees. Let's make this our cornering constant. As has been explained, in countries where we drive on the RH side of the road, the road falls away from us to the right (for water drainage). Also, on any road, a left curve takes the outer of the two radii, the right, or opposing lane, represents the inner radius (going the other way). On a right curve, the inverse is true as the right lane is the tighter and (in terms of speed) the slower of the two. As anyone who's watched a wheel go around knows, the parts closer to the axle (axis) spin slower than those farthest away from it. So if you look at any corner, left or right, as a part of a circle, i.e. an arc which has an axis, you can understand more easily how one side is the faster side depending on which way the corner goes. Now let's take that 30-degree motorcycle lean angle and carry it through a left-hand curve. The 30 degrees is measured from vertical. This assumes a road surface perpendicular to that vertical line. But it's not perpendicular and thus not really “just” a 30-degree cornering angle because if you add in the 2 degrees of road crown, you've got an effective cornering angle of 32 degrees when arcing left. Not only that, but two of those 32 degrees are being used by gravity to pull you away from your intended line, because of the negative grade represented by the road crown. Thus, in order to hold your line, your tire scrubs, but so subtly that you usually don't feel it. Still, it's wearing by sacrificing its surface to the heat and shredding that it takes to change the direction of a loaded 700-lb sport-touring bike. Now let's take that same curve and make it a right hander. Suddenly the 30 degree lean angle is reduced to 28 degrees because of the 2 degrees of camber (road crown) that works to create a positive road angle into which to arc your bike. Thus the differences between a left curve at 30 degrees of lean and a similar right curve at 30 degrees of lean, total 4 degrees. That's enough of a difference to create some different wear characteristics. More scrub and wear going left, and less going right (all else being equal). Beyond this, we can calculate in a number of other factors if we want. • Take away our constant of a 30-degree lean and in the real world, road speeds would be different (greater) through a left hander vs. a right hander. More speed, more scrub (tire wear). • Plus there's the fact that riders are generally more comfortable leaning to the left (most of us are right handed and are more protective of our natural side). Thus we're more comfortable cornering harder to the left. • Plus turning left leans our bodies away from the throttle and straightens out the right wrist which makes for more comfortable and controlled throttle application leading to earlier application (vs. leaning our bodies right which cramps the wrist's ability to rotate smoothly and often delays confident throttle application), all of which contribute to making the front tire work harder and sooner when exiting a left curve, and on an already 4-degree surface differential, • etc. etc. etc. The above, along with many other factors (many of which are touched on above) is what I've been led to believe are the major contributors to uneven front tire wear. Ten, twelve, fifteen curves per mile on your favorite set of twisties, mile after mile, through hundred and eventually thousands of miles, and the inequities build up until the tire wear differences are noticeable. Link to comment
greiffster Posted December 15, 2017 Share Posted December 15, 2017 I'm not an engineer and I don't play one on TV. But this is what I've culled from years of reading about the subject of uneven tire wear. And if I'm full of bull, one of our resident smarter people (of which we're blessed with many) will tell me so. Gently, please. Your 4 degree relative difference in lean angle breaks down with superelevated road surfaces. Most horizontal curves with design speeds that result in lean angles of 30 degrees should be superelevated. Maximum superelevation is generally about 8% and is consistent across both lanes once through the transition. The transition from normal crown to superelevation varies, but generally half to 2/3rds of the transition happens prior to the point of curvature and thus the slope differential across the two lanes is gone prior to entering the corner. Federally funded roads to include most state routes should be following the AASHTO guidelines regarding superelevation. Local and county roads are certainly less consistent. Link to comment
