joeb Posted September 29, 2017 Share Posted September 29, 2017 First a few comments on yesterdays af-xied install on my 03 1150rt. Easy install. Now that i have a few miles on it, WOW, what a difference on engine smoothness and especially throttle response. Most noticable while blipping throttle during downshifts. No more slow response. Don't notice any appreciable surging either. Using setting 7. Questuions..... Saw on other links that one should run a few tanks of gas to let system stabilize. Is this so ? How fast does a settimg change effect the fuel delivery ? For example.. If i can't get premium fuel, will changing the settimg from lets say 7 to 9 immediately increase mixture ? Also, noticed my idle rpm increased 400 rpm. Normal idle is usually around 1100. Is this a normal side effect or did i displace a throttle cable slightly while putting tank back in place ? As alwsys thanks for your input. Link to comment
Lowndes Posted September 29, 2017 Share Posted September 29, 2017 Joeb, I noticed an immediate improvement, also, on both my oilheads. It may take a few tanks thru it to get the last little bit of performance, that's what roger04 rt said and he would know. I did not notice any RPM increase. Best check the cables. Link to comment
avu3 Posted September 29, 2017 Share Posted September 29, 2017 When I finally got my bike running right, I didn't have an increase in RPM. Like Lowndes says, check that you haven't dislodged the throttle cable on one of the throttle bodies, the metal end likes to sometimes catch on the bracket where they seat. Link to comment
roger 04 rt Posted September 30, 2017 Share Posted September 30, 2017 Hi Joe, Idle sometimes increases 75-100 rpm due to the richer mixture. More than that, as others have said, may be due to pressure on your throttle cable. As I mentioned in your other thread part of the improvement occurs quickly (the short term trims in mid throttle and below area) and part takes longer (half throttle and above) due to the time it takes for the long term trims to develop. I wouldn't suggest richening the mixture to cover lower octane fuel. It may not work at all and it takes a while for long term trims to be developed for the wider throttle angles where knock is a problem. Just installed af-xied on 1150rt. Setting 7. Seems more responsive , however outside air temps are much cooler then before install so not sure how much of the improvement is attributable to the af-xied. I did notice that under load and full throttle i still got some ping. Didnt expect that, especially with cooler temps. Will try a few tanks of fuel then change settings if no improvement. It will take several tanks of fuel before the long term fuel trims have been fully populated for the high load portion of the fuel map. That said you should already notice improvements to steady throttle and roll-on acceleration. Link to comment
joeb Posted September 30, 2017 Author Share Posted September 30, 2017 Thanks for the replies. Higher RPM was due tl the cable being moved a little. The bike feels like it has a new engine. Very happy with it.. Link to comment
Shane J. Posted October 1, 2017 Share Posted October 1, 2017 I also just installed the af xied. ! It was my birthday present from my wife. Just back from a test ride, and what an improvement. R1150rt, could never get it to idle except at 1500-1600 rpm. Any lower and it would stumble and cough and sometimes just die. I have installed new throttle bodies, new injectors, done numerous throttle synchronization, tps adjustment, idle adjustments, all to no avail. After installing the afxied the bike started right up and within a couple minutes was idling comfortably at 1000rpm. After a quick 80mph run for 20 miles on the freeway and a spirited ride back on some twisters I am very impressed with the improved throttle response and smooth running. I can't wait to see how it's doing after a couple tanks of gas run through. Link to comment
roger 04 rt Posted October 1, 2017 Share Posted October 1, 2017 Shane, Glad that you saw a real improvement with the AFXIED. Have you evaluated your stick coils? They could be at the root of your poor idling. Link to comment
Shane J. Posted October 1, 2017 Share Posted October 1, 2017 "Dope slap" I thought I had. But I just tested again by pulling the connections one at a time. Wouldn't you know it, the right side makes no difference if it is connected or not. So, do I really have to replace them in pairs? Link to comment
roger 04 rt Posted October 1, 2017 Share Posted October 1, 2017 You don't have to buy two (Beemerboneyard) but I'd recommend you do since it's hard to tell the condition of the other coil. Others may disagree and you won't be wrong to buy just one. Link to comment
Craig G. Posted October 1, 2017 Share Posted October 1, 2017 I had one go bad. I replaced both and carry the used good one under the seat as a spare. Link to comment
Shane J. Posted October 2, 2017 Share Posted October 2, 2017 So probably not critical if I am buying new units as opposed to used? Link to comment
