Shorter brake lever options?
TonyRS
Is there replacement levers for brake and clutch that provide shorter grab distance than factory levers for an RS?
After fixing the leaking master cylinder I'm finding the lever firms up too far away(yes the dial is set to '1') for comfort.
Morning Tony
You can sort of bring the lever in closer to the bar by working with the adjustment (make the 0 position obtainable) but that can also get you into trouble as you could run out of lever stroke in an emergency braking event during an ABS stop.
Maybe try riding it for a while as is as most riders (even with smaller hands) get used to the lever position & it becomes a non issue over time.
