Mike Posted August 6, 2017 Share Posted August 6, 2017 These puppies are about 15-20 years old, and were worn down to slicks. I took them to a local cobbler and for $80, I now have new, beautiful Vibram soles: I wanted to share this because I often read that these sorts of repairs can't be done or that only a select few have the ability. It ain't so. A good cobbler can hook you up. Link to comment
LBump Posted August 6, 2017 Share Posted August 6, 2017 I'm curious... have you stood in 2" of water to see if they are still waterproof? Link to comment
Danny caddyshack Noonan Posted August 6, 2017 Share Posted August 6, 2017 Believe it or not, it often depends upon which prison he learned his trade in. Link to comment
Mike Posted August 6, 2017 Author Share Posted August 6, 2017 I'm curious... have you stood in 2" of water to see if they are still waterproof? I said "boot," not "boat." Actually, I'm pretty confident that this has no impact on the water resistance of the boots. The process involves shaving a small layer off the molded sole and affixing a Vibram layer with specialized glue and heat. There is no stitching or other intrusion into the sole of the boot. But, I'll let you know after I stand in 2" of water. Link to comment
szurszewski Posted August 7, 2017 Share Posted August 7, 2017 I believe the boots' waterproofness comes from a the foresk....er... that is Gore-Tex... bootie that makes up part of the lining, so even if the sole was removed completely, as long as the bootie was damaged, it should still be good to go. Link to comment
realshelby Posted August 7, 2017 Share Posted August 7, 2017 I have a pair of Joe Rocket Super Street boots that had a thin, slick sole. Bought a pair of soles off ebay, smoothed and sanded the boot soles, applied contact cement and placed the new soles on. Waited a day and trimmed the edges a bit. Not quite pro quality, but what a difference they make! Next time I'll just take mine to a cobbler too. We have our western boots done here every so often. They do an amazing job of cleaning and polishing the leather for you too. Link to comment
Bill_Walker Posted August 7, 2017 Share Posted August 7, 2017 Cool! Yeah, I'd hate to lose the waterproofness of my Gore-Tex boots, both for the occasional rain, and because I've been know to stand in a stream to cool off my feet on hot days. Link to comment
Mike Posted August 7, 2017 Author Share Posted August 7, 2017 I believe the boots' waterproofness comes from a the foresk....er... that is Gore-Tex... bootie that makes up part of the lining, so even if the sole was removed completely, as long as the bootie was damaged, it should still be good to go. I think that's correct. The original soles were molded to the uppers and there is no stitching. It's essentially matter of slicing off enough of the original sole to create a flat surface, then affixing the new Vibram layer. Hopefully it will be a durable repair; with equivalent new boots running $300-$400, it seemed like a worthwhile strategy. Link to comment
szurszewski Posted August 7, 2017 Share Posted August 7, 2017 I believe the boots' waterproofness comes from a the foresk....er... that is Gore-Tex... bootie that makes up part of the lining, so even if the sole was removed completely, as long as the bootie was damaged, it should still be good to go. I think that's correct. The original soles were molded to the uppers and there is no stitching. It's essentially matter of slicing off enough of the original sole to create a flat surface, then affixing the new Vibram layer. Hopefully it will be a durable repair; with equivalent new boots running $300-$400, it seemed like a worthwhile strategy. AND you already know they fit correctly and don't have to worry about whether or not they'll break-in properly. Link to comment
LBump Posted August 8, 2017 Share Posted August 8, 2017 I'm curious... have you stood in 2" of water to see if they are still waterproof? I said "boot," not "boat." But, I'll let you know after I stand in 2" of water. Please do... When riding in rain the accumulation and saturation of water on boots is pretty intense. Coming down from a rain suit and off the front wheel they get wet... Did the same thing you did some years ago with a pair of Alpinestars touring boots. Took them to the factory in Torrance, CA. for resoling and reconditioning. Got them back and the first time in the rain... well, they were leaking. Link to comment
