Torque wrench-torx sockets
i-beem
Diving into self-service for annual maintenance. Looking for recommendation on tools; will a 3/8 & 1/2 drive torque wrench cover or should I add a 1/4 drive as well? What's a good range of torx sockets to have on hand? (already have set of torx bits) Thanks!
These are basically all the tools I use for the maintenance on my 07
I use 3/8 drives except for some sockets that I only have for 1/4 drive.
T20 Torx socket
T25 Torx socket
T30 Torx socket
T40 Torx socket
T45 Torx socket
T50 Torx socket
T55 Torx socket
T25 key (90 deg)
 8mm Hex  socket
 8 mm - deep socket
 8 mm - socket
 7 mm - socket
14mm - socket
15 mm - deep socket (For exhaust clamp)
15 mm - socket
16 mm - deep socket (ITC -Thin wall for Spark plugs)
17mm - socket
19 mm - socket
small adjustable wrench
8 mm key
10 mm key (x2 for throttle body sync)
Ratchet extention (6")
Socket screw driver handle
Screwdriver bit socket
Screwdriver bits
Oil filter wrench
Oil cap tool
Spark plug puller tool
Front axle tool
Torque wrenchs 2.4 - 145nm (You will not need more than 60nm unless you remove the FD)
GS-911 (turn off dealer service light on 08+ & diagnostics)
Hope this helps
