David R Posted July 25, 2017 Share Posted July 25, 2017 (edited) I bought a new Ohlins front for my 2012 R1200R at 50,000 miles. It is paid for and I decided to keep it instead of trade for a new one with out Telelever. Loved the front. It has rebound and Preload adjustment with a much better spring setup. Ride and handling improved. Then I decided it would be a good idea to purchase the rear. Once I realized how good the front was, I bought the rear with rebound and compression adjustments. I installed it and attempted to mount the preload adjuster where I could reach it with out taking the seat off on the left side of the bike. It was a pain in the azz to adjust it. Too many turns, too small of a knob for my big hands. I had the same problem when the Ohlins preload adjuster was under the seat. SO I measured the spring travel from the preload adjuster. It was about 5.7 mm. I then went to my OLD STOCK shock and measured the spring travel from the stock adjuster and it was 11mm. I put the OLD STOCK preload adjuster under the seat hooked to the new Ohlins shock. Its the same size thread banjo bolt. Wala! I now can get more spring travel and do it in fewer clicks with FAR Less trouble. This really works. 15 clicks or about 1/2 then entire travel of the OLD STOCK adjuster takes me through all the spring travel on the new Ohlins shock. I have gone as far as 20 clicks. I don't dare go any more. I also have no need, with the girl (pillion) and full bags, I still get my 40 mm dynamic sag. I will measure the total spring travel with 20 clicks and post here in a few with pictures. I can turn the old knob with ease. David Edited July 25, 2017 by David R Link to comment
