Bubbadozer Posted July 19, 2017 Share Posted July 19, 2017 I'm going to replace the front brake rotor Bobbins on my 96 R1100RS with the new Bobbins I purchased from Dan Cata this week. I am wondering if they can be teplacevwhile still mounted to wheel and on bike or if I have to remove the rotors? Thanks Link to comment
eddd Posted July 19, 2017 Share Posted July 19, 2017 You'll find that the job is much easier and actually faster with the wheel removed. The rotor stays in place as you remove and replace the bobbins one at a time. Link to comment
Bubbadozer Posted July 19, 2017 Author Share Posted July 19, 2017 That's what I wondered.. thanks so much. Link to comment
szurszewski Posted July 19, 2017 Share Posted July 19, 2017 You can, though, as eddd implied, do the job with the wheel in place...I did once...but in retrospect it was silly to do it that way. Link to comment
Michaelr11 Posted July 20, 2017 Share Posted July 20, 2017 Much easier to do the replacement removing the rotors. I've done the Cata bobbin kit. Pull the wheel, use some heat on the screws holding the carriers to the wheel. Use a well fitting socket on the screws. The screws might be hex head or might be torx, depends on model year. Link to comment
