Rex R Posted July 13, 2017 Share Posted July 13, 2017 In my owner's manual, the procedures for replacing the high beam and parking light bulbs include the steps to remove and replace the speakers. However, the procedure for replacing the low beam bulb is curiously silent as to how to access the bulb cover. Is it accessed thru the speaker area, also? Link to comment
narcosis Posted July 13, 2017 Share Posted July 13, 2017 (edited) Check this thread . It can be easy, or otherwise. If you're good/lucky, you can stand in front of the bike, reach up from under the headlight, remove and replace the low beam bulb. Edited July 13, 2017 by narcosis Link to comment
dbozroz Posted July 2, 2018 Share Posted July 2, 2018 any recommendations on replacement bulb? ... like from an auto supply store? Link to comment
AndyS Posted July 3, 2018 Share Posted July 3, 2018 Search this forum for LED low and high beams. I have done it and so has Terry (Realshelby). We are both very impressed with the results. The easiest way (by far) is to remove the whole headlight assembly. I used the LED lamps that have the braided cooling element. So when these have been fanned out they (along with the ballast unit) tuck away under the removable screw cap. Link to comment
