DavidMantle Posted July 8, 2017 Share Posted July 8, 2017 (edited) I have recently fitted some handlebar lifters - the sort that bolt directly to the top yolk ( triple tree ) and that the bars bolt to. The idea being to lift and set back my bars for comfort. Fit perfectly but when I turn bars lock to lock they catch the front edge of the tank upper fairing. Any suggestions as to how alleviate this?. I can only think of grinding back some metal in order to create the clearance needed. My bike is a 1998 R1100RT. Edited July 8, 2017 by DavidMantle Link to comment
szurszewski Posted July 8, 2017 Share Posted July 8, 2017 There is some play in how the tank is mounted. I'd start by trying to see if I could move it back. Link to comment
PAS Posted July 8, 2017 Share Posted July 8, 2017 Buy the correct bar backs for the bike. Link to comment
Roger C Posted July 8, 2017 Share Posted July 8, 2017 The risers I bought were listed as bike-specific. Not knowing if this applies to your cycle, but on the R1100RT the gas tank position is adjustable but the side fairings are not--front to rear. So, when having to remove the tank, it is a good idea to mark the bracket to assure exact placement, or have a good memory. Link to comment
PAS Posted July 8, 2017 Share Posted July 8, 2017 Roger is correct, the tank can move but the holes wont line up for the tupperware. Thats why people have problems installing the screws. I leave my tank movable until I install the left side then I tighten down the tank. Link to comment
DavidMantle Posted July 8, 2017 Author Share Posted July 8, 2017 Ended up using the good old grinder to remove some meat off the lower handelbar shoulder. Barely touches the Tupperware . Taking her for a ride tomorrow ( working later this evening. If all goes well I will dismantle it and polish out any marks . But looks OK even as it is. Link to comment
