DMH Posted July 2, 2017 Share Posted July 2, 2017 Can anyone provide a bleed nipple sequence to properly bleed the abs unit with 6 points showing - and - if possible - picture please showing that sequence ? Making progress but need guidance replacement Spiegler lines throughout // 2002 RT Thanks ! Link to comment
Boomer343 Posted July 2, 2017 Share Posted July 2, 2017 (edited) http://advrider.com/index.php?resources/abs-3-service-v2-0.7/ This is a good one to download. Oops you have to be registered to download. Edited July 2, 2017 by Boomer343 Link to comment
dirtrider Posted July 2, 2017 Share Posted July 2, 2017 Can anyone provide a bleed nipple sequence to properly bleed the abs unit with 6 points showing - and - if possible - picture please showing that sequence ? Making progress but need guidance replacement Spiegler lines throughout // 2002 RT Thanks ! Morning DMH After changing brake lines or if the ABS controller was run low on fluid the use the original bleed sequence. The new bleed sequence is just for a quick maintenance bleed as a dealer cost saver. Link to comment
farmerboy Posted July 2, 2017 Share Posted July 2, 2017 One of my bleed nipples was VERY tight and it rounded off with my spanner. It may be worth using a six sided socket to crack them open before using the spanner for bleeding. Link to comment
