Imgnr Posted June 6, 2017 Share Posted June 6, 2017 The PO had disconnected the rear wheel inductice sensor. The bike seems to run fine wo it. Is it only for the Abs? Any reason i thould reconnect it? Thank you Link to comment
dirtrider Posted June 6, 2017 Share Posted June 6, 2017 The PO had disconnected the rear wheel inductice sensor. The bike seems to run fine wo it. Is it only for the Abs? Any reason i thould reconnect it? Thank you Afternoon Imgnr The rear wheel sensor is for both the ABS system & the speedometer. No need to hook it up if your ABS controller is removed. Link to comment
Imgnr Posted June 7, 2017 Author Share Posted June 7, 2017 Thank you dirtrider. On my triumph it controls firing so imperative for running. Link to comment
dirtrider Posted June 7, 2017 Share Posted June 7, 2017 Thank you dirtrider. On my triumph it controls firing so imperative for running. Morning Imgnr I can't see how the rear wheel speed sensor controls firing (if it did then the engine wouldn't run with the bike sitting still) It could have an effect on engine timing or fueling if the bike has traction control as the front to rear wheel speed diffential is used to figure rear wheel slippage for traction control concerns. Link to comment
