Imgnr Posted June 5, 2017 Share Posted June 5, 2017 (edited) Argh! Every time I attempt to do something on this bike, new problem crops up. Could someone please point me in the right direction? I bought some alloy levers and am trying to remove the old ones. Very simple right? Maybe on my other bikes. Seems like there's one bolt that goes into the cylinder rod (not sure what the name is). Both levers seem to have red loctite on them. Shattered three flat head bits using a small impact wrench. Tried drilling one out. Ended up destroying the clutch cylinder. Had to order a new one. Should've left well enough alone but since I have the levers, am I the only one having a problem removing them? What am I doing wrong? The bolts the one that's all mesed up. I tried to drill it out but seems like the thread goes into the lever so I'd have to drill the entire thing out which won't leave any room for me to grab it with some pliers. Edited June 5, 2017 by Imgnr Link to comment
McDuugle Posted June 5, 2017 Share Posted June 5, 2017 Heres a link on how to rebuild the master cylinder, step 6 seams to be the only thing that is important for what you are trying to do. It shows how to remove the lever. http://www.largiader.com/tech/r11mc/ Link to comment
Imgnr Posted June 5, 2017 Author Share Posted June 5, 2017 (edited) Thank you but unfortunately, that lever is not the same as the ones on the R1150's. It's the bolt that goes where the red arrow's pointing. The diagram doesn't show a bolt. Edited June 5, 2017 by Imgnr Link to comment
Shiny Side Up Posted June 5, 2017 Share Posted June 5, 2017 Sorry I don't have any answers for you, but if it's any comfort - your project sounds like it's going the way most of mine do... Link to comment
Imgnr Posted June 5, 2017 Author Share Posted June 5, 2017 (edited) Thanks. Have experience with universal japanese bikes from the 70s and early 80s. My go to bike is a 1995 Triumph Thunderbird. Very straightforward bikes to work on. Replacing levers on those bikes would be a 20 minute job at most. Edited June 5, 2017 by Imgnr Link to comment
Imgnr Posted June 6, 2017 Author Share Posted June 6, 2017 (edited) Okay, I'm a dummkopf. The screw is attached to a plunger that doesn't need to be unscrewed before you remove the lever assembly. My bike was crashed by the PO and the opening was pinched a bit and it was sticking. I thought it wasn't coming out because the plunger was attached to the brake cylinder. Hopefully this will help someone in the future. The good news is that the $25 (delivered) from EBay looks fantastic. If anyone wants to upgrade their lever, I highly recommend it. Should take about 30 minutes (if you're not a dummkopf like me). Edited June 6, 2017 by Imgnr Link to comment
Shiny Side Up Posted June 6, 2017 Share Posted June 6, 2017 Wow - those are some cool look'n levers.... Hmmmmm.... Link to comment
Imgnr Posted June 6, 2017 Author Share Posted June 6, 2017 Much better than oem. Folds up too. Comes in a few different colors. Link to comment
Sam Taylor Posted June 6, 2017 Share Posted June 6, 2017 Where'd you get 'em? Might get a pair for my Thunderbird Sport. Link to comment
Imgnr Posted June 6, 2017 Author Share Posted June 6, 2017 These are specifically for BMWs but im sure you can get them for TBirds. I have a 95 Tbord too. Try ebay. Link to comment
joeb Posted June 7, 2017 Share Posted June 7, 2017 So...... 2 questions as I am 3/4 dummkopf, but with proper training and effort , hopefully 7/8 is in my future. Is it just one bolt that needs to be removed and then the plunger installed in new levers, and where did you get them ? Thanks. Link to comment
Imgnr Posted June 7, 2017 Author Share Posted June 7, 2017 Follow the directions in the sheet i attached. The plunger needs to be reused and it has red loctite so you need to heat it up with a small torch or over an oven (its only attached to the lever). Youll need to remove a couple of plastic coverd on the bottom and the choke and throttle covers. Link to comment
Imgnr Posted June 8, 2017 Author Share Posted June 8, 2017 Do a search on ebay under "r2150" and "levers" and aort by lowest price. Link to comment
Imgnr Posted June 8, 2017 Author Share Posted June 8, 2017 Do a search on ebay under "r1150" and "levers" and aort by lowest price. Link to comment
