Dave P Posted May 30, 2017 Share Posted May 30, 2017 Hello all! on my 96 RT (and it has been this way the 4 years I've owned it) it will not run if the side stand is down, even in neutral. I've just put up with it all this time. Any ideas on what the issue is or if I could bypass the switch? Not a big deal, but if it's an easy thing to take care of, I wouldn't mind making it right. Thanks, Dave Link to comment
dirtrider Posted May 30, 2017 Share Posted May 30, 2017 Hello all! on my 96 RT (and it has been this way the 4 years I've owned it) it will not run if the side stand is down, even in neutral. I've just put up with it all this time. Any ideas on what the issue is or if I could bypass the switch? Not a big deal, but if it's an easy thing to take care of, I wouldn't mind making it right. Thanks, Dave Afternoon Dave That is the way they are-- If you want to get creative then there is a way to wire in a relay to allow running in neutral with the stand down. Or, you can just by-pass the side stand switch then it will run (even in gear) with the side stand down (a bit dangerous though) Link to comment
Roger C Posted May 30, 2017 Share Posted May 30, 2017 I'm happy the side stand switch still works on my 96RT. It's a great safety feature to have. Link to comment
tvpierce Posted May 30, 2017 Share Posted May 30, 2017 As indicated, it's functioning the way it was intended. Personally, I hated it. Apparently cops feel the same way, because the RTP bikes allow sidestand down, trans in neutral idling. You can buy the wire harness to make your bike act like a police model: http://www.ibmwr.org/r-tech/oilheads/run_on_sidestand/sidestand_start.shtml You can add the relay option Dirt Rider mentioned. Simply bypassing the switch worked for me. Link to comment
MontanaMark Posted May 31, 2017 Share Posted May 31, 2017 Just my 2cts: Leaving an oilhead idling is a great way to modify your sharkfins and fairing lowers. Mark Link to comment
Dave P Posted May 31, 2017 Author Share Posted May 31, 2017 Ok, I guess I'll leave it as it is. I thought in neutral it was supposed to run on the side stand, shut off when you try to pop it into gear. Thanks! Dave Link to comment
greiffster Posted May 31, 2017 Share Posted May 31, 2017 Ok, I guess I'll leave it as it is. I thought in neutral it was supposed to run on the side stand, shut off when you try to pop it into gear. Thanks! Dave Dave, BMW changed the design on the 1150RT to allow for the bike to run in neutral with the side stand down. Link to comment
Shane J. Posted May 31, 2017 Share Posted May 31, 2017 Would it run in neutral on the center stand? That would let you idle for warmup while you put on gloves, helmet, etc. Link to comment
dirtrider Posted May 31, 2017 Share Posted May 31, 2017 Would it run in neutral on the center stand? That would let you idle for warmup while you put on gloves, helmet, etc. Afternoon Shane J. Sure as long as the side stand is in the UP position. As long as the rider can rock or ride the bike off the center stand then that is viable option but if they can't then it will stall as soon as the side stand it put down to get the bike off the center stand. BMW recommends no engine warm-up in place, just start engine and ride off. Link to comment
RPG Posted May 31, 2017 Share Posted May 31, 2017 Just my 2cts: Leaving an oilhead idling is a great way to modify your sharkfins and fairing lowers. Mark Yep, I learned over the years to not start the bike until I'm ready to slap it in first and head out. RPG Link to comment
Dave P Posted May 31, 2017 Author Share Posted May 31, 2017 Yeah, I usually let it idle a minute or so after starting on the center stand when it's cold. I don't let it idle very long. The only time I put her up on the center stand is when I park it in my garage. When I get to work, run to the store etc, I usually use the side stand. Dave Link to comment
Shane J. Posted May 31, 2017 Share Posted May 31, 2017 Would it run in neutral on the center stand? That would let you idle for warmup while you put on gloves, helmet, etc. Afternoon Shane J. Sure as long as the side stand is in the UP position. As long as the rider can rock or ride the bike off the center stand then that is viable option but if they can't then it will stall as soon as the side stand it put down to get the bike off the center stand. BMW recommends no engine warm-up in place, just start engine and ride off. I would tend to agree, but I ride year round so a lot of my riding is in low temperature (30's & 40's) and I find a couple of minutes warm up beneficial in those conditions. Link to comment
