SJ David Posted May 30, 2017 Share Posted May 30, 2017 Anyone have this tool or made this tool in the san jose california area they would be willing to rent or loan? Thanks David M. San Jose, CA Link to comment
greiffster Posted May 30, 2017 Share Posted May 30, 2017 David, I've got one you can have, but I'm in Tennessee. And it's not worth the postage. Run down to Lowes or Home Depot and get you a cheap funnel and #2 rubber stopper. Drill a hole through the stopper and shove the funnel in there. Gently twist in the stopper. Yeah, it might seep a little bit, but it works fine. $5. Link to comment
dirtrider Posted May 30, 2017 Share Posted May 30, 2017 Afternoon David As Mike noted a #2 rubber stopper & funnel will work good. My preference is a long spout water bottle or other bottle with a long thin nozzle. Just cut the bottom out of the bottle then drill hole in stopper (tight fit to the bottle spout) then push the spout through the stopper hole. The reason that I like the water bottle better than a funnel is it seals to the stopper without any leaking, plus the water bottle holds a LOT more fluid than a funnel so you can fill it then bleed a large amount through without stopping the procedure to constantly refill. Link to comment
SJ David Posted May 31, 2017 Author Share Posted May 31, 2017 Thanks, I worked it out using a funnel with a cut off valve and a PVC fitting that I cut down on my lathe, worked pretty good. Thanks David Link to comment
