Rgiles Posted May 17, 2017 Share Posted May 17, 2017 Just got a 94 project rs for next to nothing, i am searching for a front master cyl. Lots of 1150 s not so many 1100s. Will the 16mm master from the 1150 work on the 94? Link to comment
dirtrider Posted May 17, 2017 Share Posted May 17, 2017 Just got a 94 project rs for next to nothing, i am searching for a front master cyl. Lots of 1150 s not so many 1100s. Will the 16mm master from the 1150 work on the 94? Afternoon Rgiles Will the 16mm M/C work?--possibly Will it have enough fluid supply capacity to maintain front braking in a long ABS stop, or with a caliper piston kicked back? maybe not. Personally I wouldn't try it unless you remove the ABS system & even then I wouldn't trust it until I made a few high speed front brake stops with the caliper pistons starting from deep in the calipers. Link to comment
