Ron-M Posted May 10, 2017 Share Posted May 10, 2017 I am calling it a lamp holder/insulator. The hard plastic piece that holds the two low beam headlight connectors allowing you to plug the connectors into the low beam headlight bulb. Mine have become brittle and have broken apart leaving the connectors naked. Is it a necessary part, and am I running a risk not having them? Link to comment
dirtrider Posted May 10, 2017 Share Posted May 10, 2017 I am calling it a lamp holder/insulator. The hard plastic piece that holds the two low beam headlight connectors allowing you to plug the connectors into the low beam headlight bulb. Mine have become brittle and have broken apart leaving the connectors naked. Is it a necessary part, and am I running a risk not having them? Morning Ron You can splice a new one on (BMW OEM is expensive) or get a generic from the auto parts store & splice that on. Personally I just leave the terminals bare as they are under the rubber cover & well protected. Having the plastic connector on just makes initially plugging it on the bulb easier. Link to comment
The Rocketman Posted May 11, 2017 Share Posted May 11, 2017 (edited) If you want cheap bulb OEM connectors, read this thread to see where I got them for 23 cents each: http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Main=82834&Number=915263#Post915263 Edited May 11, 2017 by The Rocketman Link to comment
Indy Dave Posted May 11, 2017 Share Posted May 11, 2017 Personally I just leave the terminals bare as they are under the rubber cover & well protected. +1 This works just fine and I think is actually a little simpler. Link to comment
PadG Posted May 12, 2017 Share Posted May 12, 2017 I am calling it a lamp holder/insulator. The hard plastic piece that holds the two low beam headlight connectors allowing you to plug the connectors into the low beam headlight bulb. Mine have become brittle and have broken apart leaving the connectors naked. Is it a necessary part, and am I running a risk not having them? This seem to be a fairly common problem, and instead of splicing on another standard connector, you really should look for one that is rated for higher temperature! I know that there are some out there with ceramic insulator, but high temperature plastic should be good also. Here is one: http://www.headlightplugs.com/H7.ht.html Quite cheap, IMHO! Link to comment
Ron-M Posted May 12, 2017 Author Share Posted May 12, 2017 Thanks for the suggestions Link to comment
