Jim Moore Posted May 8, 2017 Share Posted May 8, 2017 Hi guys, I need head gaskets for my 94 RS with an RT engine of indeterminate age. Looking at the MaxBMW fiche, I see two different part numbers, one "To 8/97" and one "From 8/97." I seem to remember that there was an update at one point, but I thought they were interchangeable. Will either of those gaskets fit? If not, any idea how to tell which one I need from looking at the engine? Thanks, Link to comment
lkraus Posted May 8, 2017 Share Posted May 8, 2017 http://bmwmotorcycletech.info/IDnumbrs.htm might help you figure out the production date of your engine. Link to comment
dirtrider Posted May 8, 2017 Share Posted May 8, 2017 (edited) Hi guys, I need head gaskets for my 94 RS with an RT engine of indeterminate age. Looking at the MaxBMW fiche, I see two different part numbers, one "To 8/97" and one "From 8/97." I seem to remember that there was an update at one point, but I thought they were interchangeable. Will either of those gaskets fit? If not, any idea how to tell which one I need from looking at the engine? Evening Jim There was an old BMW service bulletin on the head gasket change-- "All R1100 models produced from calendar week 18 (April 28, 1997) onwards will be equipped with head gaskets of Multi-Layered Steel (MLS) technology. Service Information: The MLS cylinder head gasket can be used in place of all earlier gaskets, on all R1100 models, without any modifications. Part Number: MSL cylinder head gasket for all R1100 models. P/N: 11 12 1 341 173" I believe the 11 12 1 341 173 has been superseded again so probably have to ask BMW what the current head gasket is for your engine. Edited May 8, 2017 by dirtrider Link to comment
