MoteroNC Posted April 15, 2017 Share Posted April 15, 2017 My 09 R1200RTP is start really rough and cutting off. If I give it throttle it will run and after two minutes it finally keeps idle. Any advice on trouble shooting? Should I start with a new tank of gas and injector cleaner? Thanks Link to comment
dirtrider Posted April 15, 2017 Share Posted April 15, 2017 My 09 R1200RTP is start really rough and cutting off. If I give it throttle it will run and after two minutes it finally keeps idle. Any advice on trouble shooting? Should I start with a new tank of gas and injector cleaner? Thanks Afternoon MoteroNC First thing to try is doing a new TPS (Throttle Position Sensor) relearn. If that doesn't help then we will need a lot more info on when the problem started & how long it has been acting up (could be a lost stepper or even a bad stick coil or coils, or??????) TPS re-learn procedure----- *Disconnect the lead to the battery's positive post for about 3 minutes. Then *Reconnect the positive lead to the battery's positive terminal. Then *Switch on the ignition. Then *Without starting the engine, fully open the throttle once or twice so that the control unit of the BMW engine management system can register the throttle-valve positions. Then *Switch off the ignition. That's it__ Link to comment
MoteroNC Posted April 15, 2017 Author Share Posted April 15, 2017 Well. I tried again this morning and it started right up. I will monitor the situation which started on Friday morning. I am thinking of doing the valve clearance procedure which has not been done for two years see if that makes the idle a bit smoother. Thank you. Link to comment
tallman Posted April 16, 2017 Share Posted April 16, 2017 What has been done,and when, at what mileage? Did you ever do a full service to have a baseline for reference? Link to comment
MoteroNC Posted April 16, 2017 Author Share Posted April 16, 2017 Yes I had the dealer do the valve check every year and replace plugs. I have been doing oil, air filter, gear and transmission myself every year. Link to comment
MoteroNC Posted April 18, 2017 Author Share Posted April 18, 2017 Yes it has but I feel I want to improve the idle performance a bit more by doing the tuning. Link to comment
