Nd4spd68 Posted April 5, 2017 Share Posted April 5, 2017 Hi all, I'm new to the R1100S community and have a question surrounding the ABS faults. Most of the research I've found hasn't answered the this question; does this version of ABS monitor the tail light bulb? More specifically, would installing an LED bulb cause a fault? This is on a late '99 R1100S... Thank you I advance for any info/insight you can share. Mark Link to comment
dirtrider Posted April 5, 2017 Share Posted April 5, 2017 (edited) Hi all, I'm new to the R1100S community and have a question surrounding the ABS faults. Most of the research I've found hasn't answered the this question; does this version of ABS monitor the tail light bulb? More specifically, would installing an LED bulb cause a fault? This is on a late '99 R1100S... Thank you I advance for any info/insight you can share. Mark Afternoon Mark If your 1100S has the old ABS II (piston) system then NO, if your bike has the later I-ABS (wizzy) brake system then YES, if your 1100S doesn't have ABS then NO. On the later I-ABS (wizzy) systems you won't get a brake failure fault light with an LED tail light but you c-o-u-l-d get a general warning light. Edited April 5, 2017 by dirtrider Link to comment
Nd4spd68 Posted April 7, 2017 Author Share Posted April 7, 2017 Thanks D.R.! I'm certain I have the ABS II system. Mark Link to comment
