RaymondO Posted February 25, 2017 Share Posted February 25, 2017 just changed Gear oil on my '05 R1200RT---no noticeable metal but a very reddish tint to the fluid?? Use bike and best I can tell--has not been changed in 45K miles. replaced with LandRover 75/90 Gear oil. Is there need for concern with the color? Thanks Ray in Va Link to comment
dirtrider Posted February 26, 2017 Share Posted February 26, 2017 just changed Gear oil on my '05 R1200RT---no noticeable metal but a very reddish tint to the fluid?? Use bike and best I can tell--has not been changed in 45K miles. replaced with LandRover 75/90 Gear oil. Is there need for concern with the color? Evening Ray Probably nothing to worry about. BMW sold a reddish colored final drive gear oil for a numbed of years & that always left a reddish looking gear oil at drain time. Not much can that can go wrong with a 1200 final drive that turns the gear oil red. Link to comment
sardineone Posted February 26, 2017 Share Posted February 26, 2017 (edited) Hi Ray,I've had gear oil in the past that had a red tint right from the bottle (Kendall synthetic). Since you are a newer member just checking, did you re-fill with revised spec 180cc of oil instead of the original spec of 230cc? Edited February 26, 2017 by sardineone Link to comment
RaymondO Posted February 26, 2017 Author Share Posted February 26, 2017 I did the 180CC and topped off gear box to the bottom of the fill hole....all good it seems---Many thanks!! Link to comment
Mark C Posted March 4, 2017 Share Posted March 4, 2017 Sorry, I should have remembered this, but I thought I heard you say once that you never saw a final drive go (R1200RT) that didn't leak first? Is that right? Mark Link to comment
dirtrider Posted March 4, 2017 Share Posted March 4, 2017 Sorry, I should have remembered this, but I thought I heard you say once that you never saw a final drive go (R1200RT) that didn't leak first? Is that right? Morning Mark I guess you have to define the term GO. I have seen a number of 1200RT final drives that had failing crown bearings that didn't leak. Probably would have eventually leaked if ridden far enough on a bad bearing but they get pretty noisy & growly long before leaking. Link to comment
