dcan Posted January 7, 2017 Share Posted January 7, 2017 Bike has 22k miles, very clean good running bike. I have read about the abs and clutch, trans, spline problems, hopefully I won't have any of them, is there anything else I should check before riding? Thanks Link to comment
avu3 Posted January 7, 2017 Share Posted January 7, 2017 Did you see that someone over on ADVRider is making a spacer that makes the clutch better fit the splines? I don't necessarily think you should do that before riding - but wanted to mention. Link to comment
Twinsig Posted January 7, 2017 Share Posted January 7, 2017 Check manufacture date of the tires. With low miles those could be a problem. Link to comment
PAS Posted January 7, 2017 Share Posted January 7, 2017 Be very cautious at slow parking lot speed. The power assisted brakes can get ya! Link to comment
MarkAZ Posted January 8, 2017 Share Posted January 8, 2017 The usual...change all the fluids, including brake & clutch. If it still has the original rubber brake lines, change to stainless steel (Spiegler, etc.). While you have the tank off doing the brakes, change the fuel filter & in-the-tank fuel lines. Make sure it has the metal quick disconnects on the fuel lines. Check the left cam chain tensioner to see if it's the updated version (the new one takes a 15mm wrench, the old 16 or 17...I forget which). Might as well check the valve clearances and do a throttle body sync while you're at it. Then ride it. I bought one a couple years ago same as yours...about 22k miles...and love it (I did all the above plus new tires). Link to comment
Boomer343 Posted January 8, 2017 Share Posted January 8, 2017 http://advrider.com/index.php?threads/r1150rt-2nd-load-relay-for-twin-spark.1073584/ Did this mod on my 03 twin spark well worth the time and effort. You can check the relays to see if yours was one of the ones that was in the factory update. Link to comment
roger 04 rt Posted January 8, 2017 Share Posted January 8, 2017 MarkAZ mentioned this above but it will take a while to rebuild the tank innards. You can quickly test the in-tank hardware quality. Measure the quantity of fuel RETURNING to the fuel tank at idle. If it is about 2 liters per minute, you can forget about replacing the hoses until it's convenient. Here's how: http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=838620#Post838620. Although the chance of a failure in the tank isn't high, it is a show stopper when it fails. Mine failed at 70 mph, in heavy traffic, while I was in the passing lane of a four lane highway. Luckily it was only a couple hundred yards to an exit. Link to comment
Bill_Walker Posted January 8, 2017 Share Posted January 8, 2017 I'll add in a couple of tips for riding. It's a top-heavy bike, especially with a full tank, and the dry clutch has a narrow friction zone, making it easy to stall. It'll take some time to get used to, and until you do, it's a very easy bike to drop. Especially avoid parking situations where you end up having to start from a stop with the bars at full lock - if the front wheel hits a small pebble, you might go down. Link to comment
dcan Posted January 9, 2017 Author Share Posted January 9, 2017 I know this sounds nuts, but I found a good deal on an 08 rt and bought it not the 04. Now I need to found out about the 08. Thanks Link to comment
