Chal De Cecco Posted October 11, 2016 Share Posted October 11, 2016 On a recent trip to Lassen National Park and the' Lost Coast', I ran into some very cold conditions for this time of year in Northern Cal. I used the grip heaters on my new RS while wearing some thinner Klim leather gloves. At first stage, the heat worked too well forcing me to turn the system off after 5 minutes. Using the second more intense stage was out of the question within a couple of minutes. All seems well with the bike. Any fix here except for maybe changing to thicker gloves. I have the stock grips on the bike. Ambient temps in some areas were between 35 and 40 degrees in the early morning/late afternoon hours. Link to comment
RTinNC Posted October 11, 2016 Share Posted October 11, 2016 Heck I wish mine worked that well! Link to comment
gordiet Posted October 11, 2016 Share Posted October 11, 2016 Don't you have four settings? Link to comment
RTinNC Posted October 12, 2016 Share Posted October 12, 2016 No ... not on my '12 GSA ... low and high. They work fine but never get so hot you have to turn them off. Same on the '06 RT. Link to comment
Tri750 Posted October 12, 2016 Share Posted October 12, 2016 (edited) You could install a set of "Origonal Grip Buddies" rubber/foam wraps that Velcro over your stock grips or foam sleeves for the grips by "Grab On" They will increase the diameter of your stock grips a bit (some folks want that) and will likely lessen the heat. Heated grips are like a heated seat or a heated vest, you'll often be adjusting the temp and turning off and on as you use them/it and the outside temp changes. In a vest or heated jacket fitted with a rheostat, it's hard to find 1 setting that's perfect. In the old days, we only had on-off switches that were constantly being played with. I bet you wish some of your vintage bikes had heated grips eh? Edited October 12, 2016 by Tri750 Link to comment
gordiet Posted October 12, 2016 Share Posted October 12, 2016 RTLC has four settings. Didn't realize the GS only had Two. Link to comment
Green RT Posted October 12, 2016 Share Posted October 12, 2016 My R has just two settings as well. I use the high to get them warmed up at first then switch to the low setting. Even on low it is a little too warm and I found my self cycling them off and on, until the temperature of the day warms up to the point where I didn't want heat at all. Link to comment
bdfbeemer Posted October 12, 2016 Share Posted October 12, 2016 Be glad. The heated grips on my XR suck. Link to comment
NoelCP Posted October 13, 2016 Share Posted October 13, 2016 Grip Puppies work great with heated grips on my '16 RT. Link to comment
JR356 Posted October 14, 2016 Share Posted October 14, 2016 Look around for gloves with a thinner palm,but insulated back. BMW and Held make a $$ 2 in 1 glove,one compartment ventilated,second is Gortex with some insulation. Found the Held version in like new condition for cheap on fleabay and they work well for 3 season CA riding for me. Glad your RS has better grips,my '14 GSA(along with others)has marginal heated grips.Apparently improved in '15 and later models. JR356 Link to comment
James L. Posted October 14, 2016 Share Posted October 14, 2016 Look around for gloves with a thinner palm,but insulated back. BMW and Held make a $$ 2 in 1 glove,one compartment ventilated,second is Gortex with some insulation. Found the Held version in like new condition for cheap on fleabay and they work well for 3 season CA riding for me. Glad your RS has better grips,my '14 GSA(along with others)has marginal heated grips.Apparently improved in '15 and later models. JR356 I find my grip heaters (2011 RT) work very well. But I must admit, I'm in the southeast, and do not suffer from the thermic conditions of the northern guys. James L Link to comment
realshelby Posted October 14, 2016 Share Posted October 14, 2016 My '14 RT has very good grip heaters. Never have I run them on the hottest setting, rarely on the lowest setting. About perfect. Mine has never had any updates since purchase, in case they "update" the heater settings like they did the seat heat for some. Link to comment
