Uggles Posted March 14, 2006 Share Posted March 14, 2006 Geday, Got a mate with a '95 R1100RT. His brake rotors (disks) appear to be two part with the main braking ring "floating" around a fixed part and held in place by several grommet shaped rings. His main concern is that there is a fair degree of play in the floating section (approx 2mm). Oh wise ones - Is this normal?? Link to comment
Wooster Posted March 14, 2006 Share Posted March 14, 2006 If the 2 mm play is lateral, then, yes, it's normal that floating rotors float that much. Geday, Wooster Link to comment
Boffin Posted March 14, 2006 Share Posted March 14, 2006 Geday, Got a mate with a '95 R1100RT. His brake rotors (disks) appear to be two part with the main braking ring "floating" around a fixed part and held in place by several grommet shaped rings. His main concern is that there is a fair degree of play in the floating section (approx 2mm). Oh wise ones - Is this normal?? Side-to-side play is intentional, it helps to prevent side pressure from the calipers. Too much fore-aft play indicates the bobins are worn. These are available from your dealer and are quite easy to replace. Andy Link to comment
bmwmick Posted March 16, 2006 Share Posted March 16, 2006 Mark, Read through this thread http://bmwsporttouring.com/ubbthreads/showflat.php/Cat/0/Number/653958/an/0/page/0#Post653958 Mick Link to comment
Uggles Posted March 16, 2006 Author Share Posted March 16, 2006 Thanks All. I've really got him worried now!! Link to comment
bmwmick Posted March 16, 2006 Share Posted March 16, 2006 Thanks All. I've really got him worried now!! Well then, Our Job Is Done. Mick Link to comment
