James L. Posted September 28, 2016 Share Posted September 28, 2016 Ok, in a different thread someone was talking about aftermarket TPM systems. I would like to know if there is one that can be fitted to a 2011 RT? The front wheel has a strange valve stem that horizontally comes out of a spoke. I can't see a way to put in a sensor with that rim. James L Link to comment
Tech1 Posted September 28, 2016 Share Posted September 28, 2016 Many of the aftermarket units thread on the stem in place of the cap. I replaced the rubber stem in the rear with a right angle aluminum hard stem to support the cap. I used it for a couple of years, then the receiver quit working properly so I have not had one since. I did like having it and would have replaced it, but I keep convincing myself that I am going to buy a new RT with TPM, still haven't pulled the trigger yet! Link to comment
6speedTi Posted September 28, 2016 Share Posted September 28, 2016 My suggestion would be find a unit that replaces the existing rubber valve stem or one that installs on the inside of the rim similar to OEM. Link to comment
dirtrider Posted September 28, 2016 Share Posted September 28, 2016 My suggestion would be find a unit that replaces the existing rubber valve stem or one that installs on the inside of the rim similar to OEM. Morning 6speedTi That's the problem there is no rubber valve stem on the front wheel. It doesn't even use a conventional valve stem but instead uses a stem that actually threads directly into the wheel spoke. Link to comment
slothy Posted September 28, 2016 Share Posted September 28, 2016 ya the front is held in via a hollow bolt inside the rim Link to comment
James L. Posted September 28, 2016 Author Share Posted September 28, 2016 My suggestion would be find a unit that replaces the existing rubber valve stem or one that installs on the inside of the rim similar to OEM. Like the guys have stated, the fron rim has a strange valve stem, like this one. James L. Link to comment
6speedTi Posted September 28, 2016 Share Posted September 28, 2016 My suggestion would be find a unit that replaces the existing rubber valve stem or one that installs on the inside of the rim similar to OEM. Morning 6speedTi That's the problem there is no rubber valve stem on the front wheel. It doesn't even use a conventional valve stem but instead uses a stem that actually threads directly into the wheel spoke. Yea, I assumed since the rear wheel of a non oem TPM's has a rubber valve stem. I thought the front did as well. My RT has TPM'S from factory. Link to comment
AnotherLee Posted September 29, 2016 Share Posted September 29, 2016 James L - Looks like a cracked spoke above that valve... Link to comment
lkraus Posted September 29, 2016 Share Posted September 29, 2016 James L - Looks like a cracked spoke above that valve... It's an arrow to indicate rotation direction, not a crack. Link to comment
James L. Posted September 29, 2016 Author Share Posted September 29, 2016 James L - Looks like a cracked spoke above that valve... That is an image pulled from the internet. I didn't have the ambition to go take a real photo of my front rim. :-) James L Link to comment
AnotherLee Posted September 29, 2016 Share Posted September 29, 2016 It's an arrow to indicate rotation direction, not a crack. Yep, I see that now. Tnx! Link to comment
Don_Eilenberger Posted September 30, 2016 Share Posted September 30, 2016 Mobiltron. Available in the US. Internal sensors. Reads even before moving. Gives temp/pressure in real time. About $130. Nice system. Put one on my first R1200R - and another one on my 2nd R1200R. The sensors on my first one are still going with around 60,000 miles on the system. If you're interested - ping me - and I'll pass along the contact info for the US importer. Link to comment
Hank R1200RT Posted October 2, 2016 Share Posted October 2, 2016 Mobiltron or Mobiletron? Link to comment
6speedTi Posted October 2, 2016 Share Posted October 2, 2016 (edited) Website link http://www.mobiletron.com/b_eng_products.asp Worldwide distributors http://www.mobiletron.com/b_eng_contactus.asp?Cu_Id=4 Two USA distributors. One in California and the other in Alabama. Alabama: http://regitar.com/ecatalog/tpms Edited October 2, 2016 by 6speedTi Link to comment
James L. Posted October 2, 2016 Author Share Posted October 2, 2016 Website link http://www.mobiletron.com/b_eng_products.asp Worldwide distributors http://www.mobiletron.com/b_eng_contactus.asp?Cu_Id=4 Two USA distributors. One in California and the other in Alabama. Alabama: http://regitar.com/ecatalog/tpms The one in Alabama is 1.5 hours from me. I could ride my bike to get it. James L Link to comment
