freetime2247 Posted September 4, 2016 Share Posted September 4, 2016 Ok guys crazy question time! How do I remove the front fender on my 2012 RT? I need to change the front tire but I can't get the fender off. I've removed the screws on both sides but don't see any other attachment points and I don't want to pull to hard. Anything else I should know about removing both front and rear tires for change out? Help! Link to comment
dirtrider Posted September 4, 2016 Share Posted September 4, 2016 Morning freetime2247 If you have all the screws out then you will probably need to pull the sides out just a little to allow the fender to slide off. Link to comment
freetime2247 Posted September 4, 2016 Author Share Posted September 4, 2016 I've got two screws out which all I can see. Don't know if there is a third or possibly more. Link to comment
Rogerl Posted September 4, 2016 Share Posted September 4, 2016 (edited) To remove the entire front fender you will need to first remove the front wheel to get at the bolts that hold it on from the bottom. A friend has a R1200RT and when we changed his front tire we just removed the front section of the fender item one on the drawing below. See the link below. https://www.ascycles.com/2/MicroList?id=52026&catID=46&catname=46%20Frame%20and%20mounting%20parts To remove the front wheel you will need to remove the brake calipers as well. To remove the back wheel you will need to loosen the muffler and rotate it out of the way to let the wheel out. You will not need to remove the brake caliper for the back wheel. Hope this helps Roger L Edited September 4, 2016 by Rogerl Link to comment
freetime2247 Posted September 4, 2016 Author Share Posted September 4, 2016 Thanks this should help! Link to comment
