Alba Posted August 29, 2016 Share Posted August 29, 2016 Glourious morning today enjoying the ride into work on dry roads. What's that feeling very unusual, gets off to take a look... Oil all over back tyre. Guess what my next learning objective is. Any how to links grateful received. Link to comment
Fil Posted August 29, 2016 Share Posted August 29, 2016 (edited) Here you go. There is plenty more info out there. Washing job to do. http://advrider.com/index.php?threads/shade-tree-mechanics-guide-to-final-drive-bearing-replacement.234400/ Edited August 29, 2016 by Fil Link to comment
dirtrider Posted August 29, 2016 Share Posted August 29, 2016 Morning Alba First off, what BMW model & year are you working on, is it your 1150RT? Next, is the oil coming from the final drive seal or the engine oil sight glass area? Link to comment
BFish Posted August 29, 2016 Share Posted August 29, 2016 had you recently changed the oil, spark plugs or anything? Link to comment
Alba Posted August 29, 2016 Author Share Posted August 29, 2016 (edited) Thanks Fil, brilliant write up with loads of photos the way i like/ need it. dirtrider its an 1150RT '02, with 44,707 miles on the clock. The oil is coming from the final drive when I take the 'rubber boot off' no running oil. Turning the rear wheel it sounds 'ruff' BFish no recent maintenance she has been running sweet. Edited August 29, 2016 by Alba Link to comment
Fil Posted August 29, 2016 Share Posted August 29, 2016 (edited) If it's the big bearing it's not a difficult job at all. You will read elsewhere about getting it shimmed, but with your mileage I see no need. If it's just the big bearing then jump to post 10 on the link. There is no real need to remove the final drive from the bike unless you want to check and grease the pivot bearings. Edited August 29, 2016 by Fil Link to comment
Alba Posted August 29, 2016 Author Share Posted August 29, 2016 Thanks Fil, lets hope it's only the big bearing really would prefer not to strip the back end down. Link to comment
dirtrider Posted August 29, 2016 Share Posted August 29, 2016 dirtrider its an 1150RT '02, with 44,707 miles on the clock. The oil is coming from the final drive when I take the 'rubber boot off' no running oil. Turning the rear wheel it sounds 'ruff' Evening Alba Then it does sound like the spool oil seal & probably the crown bearing. If you haven't ridden it very far with a trashed crown bearing then you probably won't need the tapered bearing on the other end of the spool. You can install a new crown bearing & oil seal without removing the entire final drive from the bike (just removing the rear wheel, brake caliper, & final drive side cover). I will strongly suggest that your do re-shim (or at least check) the crown bearing preload as bearings do vary a bit so you never know what pre-load is that you will end up with. If your bearing is torn up pretty bad then you will have to get in there & get all the old metallic junk out of the pinion bearing area. Link to comment
Alba Posted August 30, 2016 Author Share Posted August 30, 2016 Cheers, will be an interesting fix Link to comment
