Transmission Experts: Would you worry about this?
Santron
After reading several posts on this board about people who have happily changed their transmission fluid to the thicker Mobil 1 75W/140 synthetic gear oil, I decided to take the plunge. When I removed the drain plug, this is what it looked like (below). Is this an excessive amount of metal filings on the drain plug? I know that the the fluid hasn't been changed in 6K miles. The first shot shows the plug as it came out of the bike, and the second is after I sprayed it with brake cleaner to remove the sludge and expose only the metal finings. Should I be worried, or shopping for a new transmission?
russell_bynum
Don't worry about it, what you are seeing is normal.
Joe Frickin' Friday
Get your fingers in there and grab some of that stuff off of the magnet. I think you'll find that it's all extremely fine metallic sludge, not the slivers of metal that it appears to be. It's just the way that iron particles respond to a magnetic field; the little tiny particles follow the magnetic field lines and construct long, thin filaments that look like whole slivers of iron.
If it is indeed all really fine sludge as I suspect, then no problem; you've got a pretty normal quantity on the plug in the first pic. If it actually is chunks of metal, your gearbox is on its way out, and I'd avoid any cross-country trips until you've addressed the problem.
Yes, you are correct about that; when I cleaned the plug before reinstalling, I was amazed that it was all a fine paste with really no particles of substance - they were not the jagged little pieces of metal that they appeared to be.
Thanks for the input everyone!
