GordonB Posted March 12, 2006 Share Posted March 12, 2006 I've got my new Ohlins installed on my 2000 RT; The rear shock spring was ordered "one spring rate" up from std. It is rated for a 190-220# rider. My weight is 220# So, when setting up my ride height, the best I can do is 1-3/4" And this is with zero preload, and the one top case which is my 'basic' setting. (OHlins rec. a range of 1" to 1-1/2". If I'm at 220, shouldn't I be using preload to compensate since my weight is at the top end of the spring's rating? I'm concerned about the spring being to hvy. Link to comment
LJR Posted March 12, 2006 Share Posted March 12, 2006 You are talking about static sag, right? The difference in unloaded (on the centerstand) suspension height and that with you sitting on the bike and a buddy measuring the sag. Seems you just need to give it a little more preload to take it from 1-3/4" to the 1" to 1-1/2" range. OR maybe I'm misunderstanding your figures. BTW the 1" to 1-1/2" range is just a recommendation, something to start at. Link to comment
GordonB Posted March 12, 2006 Author Share Posted March 12, 2006 I'm talking Ride Height; Difference between measurements from Shocks fully extended (no weight, bike on center stand) and Bike with rider on it (shocks under load). Link to comment
GordonB Posted March 12, 2006 Author Share Posted March 12, 2006 Problem solved, I fig'd it out. Link to comment
