freetime2247 Posted July 15, 2016 Share Posted July 15, 2016 Hit the horn button on my 2012RT this am and now I can't get the horn to stop. The switch is broken. I called the local BMW shop and they have order another left handle bar switch which was just replaced under recall 10 months ago. I would think BMW's QC would be much better. I have an 06 Honda ST1300 that I have rode over 94k miles without any electrical failures. My RT has just 13K miles and now I have to replace another switch. It's still a great bike I just wish things didn't break so often. Link to comment
Indy Dave Posted July 17, 2016 Share Posted July 17, 2016 Hi Freetime. Is it possible a bug (or spilled drink if you use a cup holder) or something has made its way into the switch/spring area and got squashed when the button was pressed, and the ensuing goo has discouraged the switch from disengaging? You might try spraying some electrical cleaner inside the switch or remove it. It's frustrating when things go wrong / break. When I read your topic, the first thing I thought of the the horn sticking scene on the VW bus in 'Little Miss Sunshine'. What other issues have you been having? Link to comment
Skywagon Posted July 17, 2016 Share Posted July 17, 2016 spray it with Corrosion X and keep pushing the button. If it is wet, corroded, etc... Corrosion X will clean it up. If that isn't it then one of two things likely...the button assembly or the horn relay. I had a horn relay go south a few years ago and has similar issue on an airhead. Link to comment
freetime2247 Posted July 18, 2016 Author Share Posted July 18, 2016 I've had no other issues with the bike. The dealer did tell me the horn button was most likely broken and they would replace the whole cluster. However, I will try WD40 tonight and see if that frees up the button. Link to comment
Mike Posted July 19, 2016 Share Posted July 19, 2016 I've had no other issues with the bike. The dealer did tell me the horn button was most likely broken and they would replace the whole cluster. However, I will try WD40 tonight and see if that frees up the button. Probably too late for,this, but I wouldn't use regular WD-40, which eventually turns gummy. There's a WD-40 Electrical Contact Cleaner. Also, DeOxit is an excellent product that often restores electrical contacts to like-new condition. Link to comment
freetime2247 Posted July 20, 2016 Author Share Posted July 20, 2016 Left switch cluster replaced by dealer under warranty. Works like new again! Link to comment
6speedTi Posted July 21, 2016 Share Posted July 21, 2016 Left switch cluster replaced by dealer under warranty. Works like new again! Yup that pretty much is the fix for it. Glad your back on the road. Link to comment
