mikeR1100R Posted March 12, 2006 Share Posted March 12, 2006 Has anyone installed braided steel brakelines in the configuration that Galfer calls "Superbike" for the front brakes? This involves two separate lines, one for each of the 2 front discs, secured to the master cylinder by a double banjo bolt. The stock assembly for the front brakes on my '98 R1100R seems absurdly complicated. The so-called Superbike setup seems much simpler and easier to install. Thoughts, opinions? Thanks, Mike Link to comment
Dances_With_Wiener_Dogs Posted March 12, 2006 Share Posted March 12, 2006 Seems like a fine idea, unless your R has ABS. If so, I believe the MC runs to the ABS and then from the ABS to your calipers. Link to comment
