pdpwcd Posted June 20, 2016 Share Posted June 20, 2016 2015 rt with 6100 miles riding at highway speed motor goes down to about 1000 rpm lucky to be able to get off freeway to safe spot check engine light came on after a bit while waiting for tow truck tried bike and seemed to run fine but had it towed home anyway will go to dealer tomorrow hope there is a record of what happened first BMW for me Link to comment
strataj Posted June 20, 2016 Share Posted June 20, 2016 Strange... Please keep us posted Jay Link to comment
Jriffe108 Posted June 21, 2016 Share Posted June 21, 2016 Interesting, I'd venture to say it's the Egas electronic throttle. let us know Link to comment
Stbell Posted June 21, 2016 Share Posted June 21, 2016 Unbelievable. Hopefully it is an easy fix. Keep us updated. Link to comment
LAF Posted June 22, 2016 Share Posted June 22, 2016 Sounds like switch gear to me.................. Link to comment
pdpwcd Posted June 22, 2016 Author Share Posted June 22, 2016 got the word from Livermore BMW that it was the throttle sensor the tech cleared the data took the bike for a ride and nothing showed as being faulty. The same thing was true when I rode the bike to the shop it ran fine. The problem I am having is the limp mode for the throttle sensor is about 1000 rpm. My son was lucky that last Sunday the traffic was very light so he was able to get off the freeway. If this were to happen again in heavy traffic you could get slammed. I do not blame Livermore for the decision that everything is fine I believe I will go to the next step to see about a new throttle sensor Link to comment
Mike Posted June 23, 2016 Share Posted June 23, 2016 got the word from Livermore BMW that it was the throttle sensor the tech cleared the data took the bike for a ride and nothing showed as being faulty. The same thing was true when I rode the bike to the shop it ran fine. The problem I am having is the limp mode for the throttle sensor is about 1000 rpm. My son was lucky that last Sunday the traffic was very light so he was able to get off the freeway. If this were to happen again in heavy traffic you could get slammed. I do not blame Livermore for the decision that everything is fine I believe I will go to the next step to see about a new throttle sensor I can't say that I blame you, but I'd also note that, in the age of cars and motorcycles having morphed into rolling computers, these things often turn out to be one-time occurrences. Link to comment
realshelby Posted June 23, 2016 Share Posted June 23, 2016 I will add that I too would want a NEW throttle position sensor! I do a lot with DL and SV 1000 Suzukis in my business. One of their quirks is having them act up after riding at speed and in warmer conditions. They will die when pulling up to a stop sign after getting off the Interstate for instance. Then restart and they are fine for a while. Not at all uncommon, the problem is the Throttle Position Sensor. Owners will try to adjust them, say prayers over them, and whatever to keep from replacing them. They will show on a meter to work properly. But when they get hot, they fail. Replace them and all the problems go away. Even some you didn't realize you were having...... Link to comment
pdpwcd Posted July 7, 2016 Author Share Posted July 7, 2016 Bmw has decided that they will not replace the throttle sensor being that the fault cleared and the bike ran fine when the tech took it for a two mile ride. The funny part is that the original statement I made to BMW about the safety aspect of the limp mode going to 1000 rpm cannot be returned to me. My next step is through my local dealer and he will talk to the district engineering type I will see where that goes.I still feel this is a danger maybe nothing will be done now but someone should seriously look at making the limp mode rpm higher. Link to comment
lkraus Posted July 7, 2016 Share Posted July 7, 2016 I don't think that the low rpm was a choice by BMW, or a limp mode. I suspect the electrical signal from the throttle was not being received so the engine was just running at idle speed. Link to comment
