tpfeffer Posted May 14, 2016 Share Posted May 14, 2016 Just curious, is there a reason you couldn't use the final drive vent to fill the drive on a 2013 R1200RT? The vent appears to be a soft rubber plug of sorts that might be able to be pulled out and reused. The diameter of the fill hole looks small, ~6mm, so it might be a slow process to fill with the recommended 180 cc. However, I wouldn't think it would be any slower than removing the wheel to gain access to the fill hole and using a syringe to squirt in the fluid. What am I missing? Link to comment
dirtrider Posted May 14, 2016 Share Posted May 14, 2016 Morning Tom Maybe but it would probably take w-a-a-a-y longer than removing the tire & using the fill plug. Remember there is no other vent so trying to get thick gear oil in through the vent would probably pressure-lock the small fill hole. I suppose you could try it then let us know if it works in a reasonable time frame. Personally I just change the final drive oil at rear tire change time so all is easy to access. Link to comment
Dave_in_TX Posted May 14, 2016 Share Posted May 14, 2016 Just curious, is there a reason you couldn't use the final drive vent to fill the drive on a 2013 R1200RT? The vent appears to be a soft rubber plug of sorts that might be able to be pulled out and reused. The diameter of the fill hole looks small, ~6mm, so it might be a slow process to fill with the recommended 180 cc. However, I wouldn't think it would be any slower than removing the wheel to gain access to the fill hole and using a syringe to squirt in the fluid. What am I missing? I've tried it and DR is right. When using the vent to fill, you need to add very slowly or it will overflow the vent tube. Link to comment
tpfeffer Posted May 21, 2016 Author Share Posted May 21, 2016 Oh well. I was looking for the what to me would be the obvious way to fill the FD; just like on oil heads, air heads, and so forth. It's hard to understand BMW's reasoning some times. When %$&X^ happened on my Guzzi, a friend consoled me with, "It's a Guzzi." That might work for Italian iron but it doesn't cut mustard for teutonic steel. Link to comment
Dave_in_TX Posted May 21, 2016 Share Posted May 21, 2016 You might try the "tool" shown here http://advrider.com/index.php?threads/cheap-easy-final-drive-lube-tools.1130043/. That might allow you to add oil slowing enough while providing room for air to escape. Link to comment
