arkmark Posted May 9, 2016 Share Posted May 9, 2016 what are the torque specs for: front axle axle pinch bolt front brake calipers front brake rotors 2012 1200rt Link to comment
BMW_Ken Posted May 9, 2016 Share Posted May 9, 2016 what are the torque specs for: front axle axle pinch bolt front brake calipers front brake rotors 2012 1200rt front axle - 50 NM axle pinch bolts - 19 NM front caliper bolts - 30 NM rear caliper bolts - 24 NM Link to comment
arkmark Posted May 9, 2016 Author Share Posted May 9, 2016 thank you very much, any idea for the front brake rotors? Link to comment
Tourmaster Posted May 10, 2016 Share Posted May 10, 2016 arkmark... Front brake, brake disc to front wheel: Lay brake disc on the wheel rim with the beading of the rivets to the outside. Flat-head screw for rivet package, M8 x 27 - 10.9, Replace screws, use thread-locking compound. Tighten by stages in diagonally opposite sequence, to 19 Nm Rick. Link to comment
slothy Posted May 10, 2016 Share Posted May 10, 2016 https://dl.dropboxusercontent.com/u/22757198/r1200rt%20front%20caliper.pdf https://dl.dropboxusercontent.com/u/22757198/r1200rt%20front%20brake.pdf https://dl.dropboxusercontent.com/u/22757198/r1200rt%20front%20tire.pdf Link to comment
