BlueRidgeBoy Posted March 7, 2006 Share Posted March 7, 2006 I searched the forum ... I promise. Is it possible to replace the oil pressure indicator light bulb in the dash (98 RT) without disassembly of tupperware? I can grab the rubber bulb holder but can't seem to pull it out and I don't want to pull on the wires. If not what do I take apart? The owner's manual doesn't cover this at all. search text part number 62142306126 part number B57 02 55 62 14 2 306 126 $3.77 from Bogart's Link to comment
Bernie Posted March 7, 2006 Share Posted March 7, 2006 Are you sure it is a bad lightbulb? I thought mine was bad, but it turned out to be a bad oil pressure switch. Check your switch frist. Short out the wire going to the switch and see if the light bulb starts working, if yes you need a new oil pressure switch. Link to comment
Ken H. Posted March 7, 2006 Share Posted March 7, 2006 I can grab the rubber bulb holder but can't seem to pull it out You've got the right idea. They're a pretty tight fit, but if you wiggle it back and forth, it will come out. Link to comment
