joeb Posted February 24, 2016 Share Posted February 24, 2016 Hi all. Just looked at Bigfish's post about changing brake lines and working on pistons. It was stated that brake fluid flush had to be done at servo. Question, if the fluid that was bleed out at the wheel was topped off at the upper reservoir,and topped off till clear fluid came out at wheel bleed nipple, wouldn't that eventually flush all the way thru the system, including the servo ? Link to comment
Bigfish Posted February 24, 2016 Share Posted February 24, 2016 I believe it is a completely separate circuit but now you're making me wonder if it is all connected. Link to comment
AndyS Posted February 24, 2016 Share Posted February 24, 2016 Hi all. Just looked at Bigfish's post about changing brake lines and working on pistons. It was stated that brake fluid flush had to be done at servo. Question, if the fluid that was bleed out at the wheel was topped off at the upper reservoir,and topped off till clear fluid came out at wheel bleed nipple, wouldn't that eventually flush all the way thru the system, including the servo ? Sorry, They are different circuits and won't work. The 1150's are different to the 1100's and are effectively 4 different circuits. 2 for the front, and 2 for the rear. Link to comment
Twinsig Posted February 24, 2016 Share Posted February 24, 2016 Joeb, read the ABS3 tutorial, lots of great info.... Link to comment
joeb Posted February 24, 2016 Author Share Posted February 24, 2016 Question. Does the ABS3 tutorial also apply to a 03rt system ? Thanks. Link to comment
Michaelr11 Posted February 24, 2016 Share Posted February 24, 2016 Question. Does the ABS3 tutorial also apply to a 03rt system ? Thanks. Yes. ABS3 is also referred to as integrated ABS. Your 1150RT has the iABS system. Think of it as FOUR separate brake fluid circuits. Controls to ABS, front and rear. ABS to wheel caliper, front and rear. Each circuit gets flushed. Link to comment
MarkAZ Posted February 25, 2016 Share Posted February 25, 2016 Joeb, read the ABS3 tutorial, lots of great info.... I don't know that I've seen that tutorial. Could someone post a link to it? Thanks... Link to comment
AndyS Posted February 25, 2016 Share Posted February 25, 2016 Here you go. iABS service: http://advwisdom.hogranch.com/Wisdom/service_abs3.pdf Link to comment
MarkAZ Posted February 26, 2016 Share Posted February 26, 2016 Thanks, Andy. I had seen that. I pretty much followed it when I flushed mine a while back. It's due again... Link to comment
