MotoBones Posted January 16, 2016 Share Posted January 16, 2016 I took the right pannier off my '14 RT today and heard something drop on the garage floor. It was the little guide plate that fits onto the footrest subframe where you over slide the pannier so everything lines up and stays in place when you put the pannier back on. I slid the guide plate back onto the footrest subframe and realized the two screws that are supposed to hold it in place were missing. I double checked the screws on the other side of the bike and both were loose enough to remove with my fingers. To save yourself a hassle over two 50-cent screws, go see if these screws (Phillips) are loose on your bike. Same for GT/L. You need to remove the pannier to access the screw heads -- assuming they're there! If they're missing, you need M4X10 self-tapping screws with button heads (part number 07 11 9 906 033). Rather than drive around to find a hardware store with a metric bolt drawer that has M4X10 self-tappers with a rust-resistant coating, I just ordered from MaxBMW's website. 50 cents each. Scroll down for the USPS shipping option...about half the cost of the default option. http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=56210 Bring up the schematic for REAR FOOTRESTS 46_1624 Item 9 (part number 07 11 9 906 033) is a self tapping M4X10 screw. Each guide plate (Item 8) is supposed to be secured by two of these screws. If the guide plate is gone, you need part number 46 71 7 674 211. The screws are going back in with a drop of blue thread lock. Link to comment
narcosis Posted January 16, 2016 Share Posted January 16, 2016 Holy crap! The screws were just about to fall out on the right side of my bike. Left side was fine. Thanks for the heads up! Ken Link to comment
realshelby Posted January 16, 2016 Share Posted January 16, 2016 Right side had one screw quite loose and the other just needed snugged. Left side were tight. Good tip! Link to comment
Clievma Posted January 16, 2016 Share Posted January 16, 2016 Both sides had one screw almost all the way out with the second just nipped. Will thread-lock tomorrow. Thanks for the heads-up. Mike Link to comment
gordiet Posted January 17, 2016 Share Posted January 17, 2016 I took the right pannier off my '14 RT today and heard something drop on the garage floor. It was the little guide plate that fits onto the footrest subframe where you over slide the pannier so everything lines up and stays in place when you put the pannier back on. I slid the guide plate back onto the footrest subframe and realized the two screws that are supposed to hold it in place were missing. I double checked the screws on the other side of the bike and both were loose enough to remove with my fingers. To save yourself a hassle over two 50-cent screws, go see if these screws (Phillips) are loose on your bike. Same for GT/L. You need to remove the pannier to access the screw heads -- assuming they're there! If they're missing, you need M4X10 self-tapping screws with button heads (part number 07 11 9 906 033). Rather than drive around to find a hardware store with a metric bolt drawer that has M4X10 self-tappers with a rust-resistant coating, I just ordered from MaxBMW's website. 50 cents each. Scroll down for the USPS shipping option...about half the cost of the default option. http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=56210 Bring up the schematic for REAR FOOTRESTS 46_1624 Item 9 (part number 07 11 9 906 033) is a self tapping M4X10 screw. Each guide plate (Item 8) is supposed to be secured by two of these screwse . If the guide plate is gone, you need part number 46 71 7 674 211. The screws are going back in with a drop of blue thread lock. Are you referring to the plate that the passenger foot pegs are attached to? If so both sides are tight. GT Link to comment
gordiet Posted January 17, 2016 Share Posted January 17, 2016 Ok, I found what you are talking about. Both loose,both sides. Thanks... GT Link to comment
ADulay Posted January 17, 2016 Share Posted January 17, 2016 I took the right pannier off my '14 RT today and heard something drop on the garage floor. It was the little guide plate that fits onto the footrest subframe where you over slide the pannier so everything lines up and stays in place when you put the pannier back on. I slid the guide plate back onto the footrest subframe and realized the two screws that are supposed to hold it in place were missing. I double checked the screws on the other side of the bike and both were loose enough to remove with my fingers. To save yourself a hassle over two 50-cent screws, go see if these screws (Phillips) are loose on your bike. Same for GT/L. You need to remove the pannier to access the screw heads -- assuming they're there! If they're missing, you need M4X10 self-tapping screws with button heads (part number 07 11 9 906 033). Rather than drive around to find a hardware store with a metric bolt drawer that has M4X10 self-tappers with a rust-resistant coating, I just ordered from MaxBMW's website. 50 cents each. Scroll down for the USPS shipping option...about half the cost of the default option. http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=56210 Bring up the schematic for REAR FOOTRESTS 46_1624 Item 9 (part number 07 11 9 906 033) is a self tapping M4X10 screw. Each guide plate (Item 8) is supposed to be secured by two of these screws. If the guide plate is gone, you need part number 46 71 7 674 211. The screws are going back in with a drop of blue thread lock. If this is the plate/screws you're talking about, then the two on the right side were "loose" and the two on the left side appeared adequately tight. Thanks for the heads up. AD Link to comment
MotoBones Posted January 17, 2016 Author Share Posted January 17, 2016 Yes, those are the screws. Link to comment
tallman Posted January 17, 2016 Share Posted January 17, 2016 '03 GT Tight as a drum. Must have a new assembler on the line. Link to comment
TEWKS Posted January 17, 2016 Share Posted January 17, 2016 Ok, to the garage I go. Edit Slight turn on right side. Thanks! Pat Link to comment
hopz Posted January 17, 2016 Share Posted January 17, 2016 You guys always thought I had a screw loose... well, not exactly... I had two loose... starboard side. Port side tight. Alert the Mothership! Link to comment
strataj Posted January 17, 2016 Share Posted January 17, 2016 If someone is keeping a list I too had a screw loose . Yep left side both of them. I also let my local club in on the issue. Thanks to the OP! Jay Link to comment
A-Red Bill Posted January 17, 2016 Share Posted January 17, 2016 Too late for me, right plate already missing. $5.00 plus $1.00 for fasteners. Left plate is loose. Might be cheaper to pay for the missing parts rather than ride the 100 or so miles to and from the dealer. Thanks for the heads up. Link to comment
Skywagon Posted January 17, 2016 Share Posted January 17, 2016 Red bill....check your luggage, small possibility it might be stuck in the grove. Checked mine this morning...both sides were tight. Will put it on the occasional check list. Link to comment
A-Red Bill Posted January 18, 2016 Share Posted January 18, 2016 Checked, no luck. I commute with the panniers off so it likely left the bike after the last weekend trip. Link to comment
biker01red Posted January 18, 2016 Share Posted January 18, 2016 Checked mine today, both screws were loose on both sides!!!! Thanks for the tip.... Link to comment
Alfred02 Posted January 18, 2016 Share Posted January 18, 2016 Checked mine They weren't loose in a sense of easy turning, just not tight to the point where I couldn't get easily another 1/2 turn on them. As the caps are plastic, making them over tight would probably just distort the plastic. So this weekend I will add some blue Loctite. Thanks for the tip. Link to comment
lkraus Posted January 18, 2016 Share Posted January 18, 2016 So this weekend I will add some blue Loctite. The blue Loctite I have says "Not Recommended For Use on plastic parts, particularly thermoplastic materials where stress cracking of the plastic could result." I've seen some reports that it also eats nylon. An alternative is the rather expensive Loctite 425 thread lock, which is intended for plastics, but it is essentially just cyanoacrylate (SuperGlue). Link to comment
gordiet Posted January 19, 2016 Share Posted January 19, 2016 Why not just check them occasionally? Done deal! GT Link to comment
bdfbeemer Posted January 19, 2016 Share Posted January 19, 2016 Do the screws go into plastic inserts or metal threads? Link to comment
PadG Posted January 19, 2016 Share Posted January 19, 2016 So this weekend I will add some blue Loctite. The blue Loctite I have says "Not Recommended For Use on plastic parts, particularly thermoplastic materials where stress cracking of the plastic could result." I've seen some reports that it also eats nylon. An alternative is the rather expensive Loctite 425 thread lock, which is intended for plastics, but it is essentially just cyanoacrylate (SuperGlue). Yeah, but you are not using it on plastic! It's on the thread of steel screw that goes into threaded aluminum piece! Link to comment
duckbubbles Posted January 19, 2016 Share Posted January 19, 2016 Do the screws go into plastic inserts or metal threads? The screws thread into the metal footrest brackets. I got 1/4 turn on all four, probably compressing the plastic slightly. Frank Link to comment
lkraus Posted January 19, 2016 Share Posted January 19, 2016 Yeah, but you are not using it on plastic! It's on the thread of steel screw that goes into threaded aluminum piece! My misunderstanding. Probably assumed the screws went into plastic when I read that these were self threading screws, something I had not seen on a BMW before. Link to comment
WBinDE Posted January 19, 2016 Share Posted January 19, 2016 You guys are too much. Genuine BMW screws for 50 cents? Five bucks for a piece of plastic? Clearly counterfeit, and you just compromised your warranty. Link to comment
MotoBones Posted January 19, 2016 Author Share Posted January 19, 2016 Do the screws go into plastic inserts or metal threads? Look like metal threads to me. Link to comment
Clievma Posted January 19, 2016 Share Posted January 19, 2016 They are machine screws not self tappers and screw into threaded holes in aluminium rear footrest hangers. Link to comment
MotoBones Posted January 20, 2016 Author Share Posted January 20, 2016 On Diagram 46_1624, the fasteners in question are described like this: 07 11 9 906 033 SELF TAPPING SCREW - M4X10 $0.50 http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=56210 Link to comment
PadG Posted January 20, 2016 Share Posted January 20, 2016 Yeah, but you are not using it on plastic! It's on the thread of steel screw that goes into threaded aluminum piece! My misunderstanding. Probably assumed the screws went into plastic when I read that these were self threading screws, something I had not seen on a BMW before. Me too. They are self-tapping screws, and possible because the aluminum that they are threaded into is cast material (probably die-cast), and therefore fairly soft. Link to comment
duckbubbles Posted January 20, 2016 Share Posted January 20, 2016 The Wetheads may be different, but my '11 RT has 4mm machine screws in that part. I removed one after seeing this discussion. Frank Link to comment
bdfbeemer Posted January 21, 2016 Share Posted January 21, 2016 Checked mine last night. All were tight. Link to comment
mhr1943 Posted January 21, 2016 Share Posted January 21, 2016 Thanks for the tip. Just checked mine. One screw on each side very loose, the two other screws also needed tightening. Proves the value of the forum. Link to comment
TimRT Posted January 23, 2016 Share Posted January 23, 2016 Got out the lock-tite and went to check mine, but they were all snug. I never ride without the bags, though. I wonder if that has anything to do with it (screws are somewhat captured when the bags are on). Link to comment
garr2 Posted January 26, 2016 Share Posted January 26, 2016 I found mine to be loose a couple of weeks after taking delivery of my 2015 RT. I nipped them up and have found them secure each time I have checked since. Sounds like someone on the assembly line is having too many late nights. Ian Link to comment
MR THUMPER Posted January 27, 2016 Share Posted January 27, 2016 August Build 2015 both sides loose a little Locktite 243 will fix it for good Link to comment
MotoBones Posted January 27, 2016 Author Share Posted January 27, 2016 Got out the lock-tite and went to check mine, but they were all snug. I never ride without the bags, though. I wonder if that has anything to do with it (screws are somewhat captured when the bags are on). "Somewhat" is the operative word there. I ride with bags all the time, yet the screws on the right side of my bike were parts unknown. Link to comment
ehc0720 Posted January 29, 2016 Share Posted January 29, 2016 I had been riding without my bags on the last couple of times out. Reading this I thought for sure mine would be gone, but, nope both sides really loose but parts are all there. Caught just in time. Thanks for the heads up!!! 2105 R1200RT, Ebony Link to comment
Bobup Posted February 6, 2016 Share Posted February 6, 2016 Thanks for the heads up. 3 ready top to fall out,one tight. Link to comment
LudemJo Posted February 10, 2016 Share Posted February 10, 2016 Just checked mine. All four are tight. No issues. John Link to comment
Dave Stephens Posted March 16, 2016 Share Posted March 16, 2016 I took the right pannier off my '14 RT today and heard something drop on the garage floor. It was the little guide plate that fits onto the footrest subframe where you over slide the pannier so everything lines up and stays in place when you put the pannier back on. I slid the guide plate back onto the footrest subframe and realized the two screws that are supposed to hold it in place were missing. I double checked the screws on the other side of the bike and both were loose enough to remove with my fingers. To save yourself a hassle over two 50-cent screws, go see if these screws (Phillips) are loose on your bike. Same for GT/L. You need to remove the pannier to access the screw heads -- assuming they're there! If they're missing, you need M4X10 self-tapping screws with button heads (part number 07 11 9 906 033). Rather than drive around to find a hardware store with a metric bolt drawer that has M4X10 self-tappers with a rust-resistant coating, I just ordered from MaxBMW's website. 50 cents each. Scroll down for the USPS shipping option...about half the cost of the default option. http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=56210 Bring up the schematic for REAR FOOTRESTS 46_1624 Item 9 (part number 07 11 9 906 033) is a self tapping M4X10 screw. Each guide plate (Item 8) is supposed to be secured by two of these screws. If the guide plate is gone, you need part number 46 71 7 674 211. The screws are going back in with a drop of blue thread lock. MotoBones - I saved your post to a Word document and have had it taped to my garage fridge for some time now. Since the weather has warmed up and I've been riding a bunch, I finally referred to your post and sure enough mine were lose as well. I applied the Blue Loctite and expect no more problems. Thanks so much for your thorough post as you've saved me (and others I'm sure) the hassle having to deal with missing screws! Link to comment
MotoBones Posted March 19, 2016 Author Share Posted March 19, 2016 Glad to help, David. Link to comment
