Christo Posted December 21, 2015 Share Posted December 21, 2015 Hello, Does anyone know the difference between Marakesh Red/Marakeschrot (Paint Code 658) and Marakesh Red/Marakeschrot "2" (Code 738)? This is for a '95 R1100RS. I have color code 658, and am m trying to buy a replacement panel with color 738, and the only link I could find that shows *both* these color chips was this: http://www.cyclecolor.com/ID21.HTM I overlayed these chips in Photoshop and they appear to be the same color (assuming the online chips are accurate). I'm trying to determine if these colors would clash on the same bike? Thanks! Link to comment
Ozonkiller Posted December 22, 2015 Share Posted December 22, 2015 According to the BMW fische, they list the '95 as 658 Link to comment
Christo Posted December 22, 2015 Author Share Posted December 22, 2015 My apologies, in the title I meant to say "Code 658", not 358. Yes, my paint code is 658. I'm trying to see how close a part with color code 738 would match my bike. Any ideas? Link to comment
Tri750 Posted December 22, 2015 Share Posted December 22, 2015 There is paint code and a color code for each color. They are different numbers. Use a parts fische such as Max BMW. You will see one number given for body panels pre-painted and another number given for touch up paint for any given color. I hope that makes sense Link to comment
Christo Posted December 22, 2015 Author Share Posted December 22, 2015 I'm just looking at body panel color codes, to see if one panel would clash with another. I checked Max's and couldn't find the 738 paint code mentioned for the R1100RS, for touch-up or whatever. The only clue I could find was on the following link: http://parts.bmwmotorcycles.com/p/BMW_1996_R1100RS/TAIL-PART-UPPER-MARRAKESCHROT/42785680/52532323670.html From this link it appears that Marrakesh red 738 was used on bikes with the Marrakesh Red/Arctic Silver combo, and Marrakeschrot 658 was the code used on the all-red bikes. Possibly as seen on the following page: http://www.bmbikes.co.uk/schemepages/schemer1100rs.htm Still not sure how similar 658 and 738 are. Using Phil Hawksley's website from above, 658 and 738 are "Marakesh Red", and "Marakesh Red 2", respectively. And using those color names from cyclecolor.com to match chips, they seem to be very similar, if not the same. This is a lot of extrapolation but the best I can come up with at the moment Link to comment
The Rocketman Posted December 22, 2015 Share Posted December 22, 2015 Holt BMW, paint expert can answer your questions, without a doubt. 740-593-6690 Link to comment
Christo Posted December 23, 2015 Author Share Posted December 23, 2015 Ok, thanks for the tip! I tried the local dealer earlier about paint and did not get solid answers. Link to comment
CaptainKcorb Posted December 24, 2015 Share Posted December 24, 2015 While not a paint expert, I have a 2000 RT in red, and remember meeting a couple of riders a few years back, one with an early year red RT. It had a visibly different hue to the paint, a little more towards an orange if I remember correctly, though it was definitely red. It wasn't a matter of fading either, as the tank top was the same hue as the lowers. I'd be thinking you'd notice the difference with two panels side by side. Good luck Link to comment
Christo Posted December 28, 2015 Author Share Posted December 28, 2015 Thanks CaptainKcord! I think you are right. I ended up not buying the part with the '738' paint code (mine is 658) Instead I bought a part from a 1994 model year bike (one year earlier). I checked and the 1994 R1100RS used Paint code 658 for Marakesh Red, just like my 1995 model. Link to comment
