beemer2000 Posted March 3, 2006 Share Posted March 3, 2006 Bob's BMW has Bob's Wrist Rest ($93) Throttlemister ($100) Kaoko ($86) Vista Cruise ($45) This has probably been through this forum before but I missed it if it did. Could anyone with experience on some of these elaborate on pluses and minuses for me???? What's the best bang for the buck? Link to comment
Rob L Posted March 3, 2006 Share Posted March 3, 2006 I currently have the Throttlemeister. Had Bob's Wrist Rest on my 98 RT. They both work equally well. Throttlemeister turns on in the same direction as opening throttle, bob's works the opposite direction. Throttlemeister is smoothe and you can get polished, bob's has knurled adjuster. Both look pretty good. They have limited use i.e. open road with no hills or turns. Good way to flex your hand after riding for a while. Another choice or add to the above is a Throttle Rocker. Cheap plastic assembly that slips over the grip and provides a short lever for your wrist to rest on. Takes a lot of pressure off of your wrist. Link to comment
Firefight911 Posted March 3, 2006 Share Posted March 3, 2006 See the very recent thread entitled: Why not to install the throttlemeister? The link is below: http://bmwsporttouring.com/ubbthreads/showflat.php/Cat/0/Number/648950/an/0/page/1#Post648950 Good Luck! Link to comment
Trebor Posted March 4, 2006 Share Posted March 4, 2006 I've got this, can highly recommend. At least I think that's the one, as there is no picture. Mine is simply a replacement plastic housing above the starter switch and a metal screw that you can adjust how much force it takes to turn the throttle. BMW part actually costs less than aftermarket. found the part on ascycles parts fiche. It's not pictured, but you can get the idea from the standard part (1). Total cost has gone up (~$70), but you might find a discount online. cheers Link to comment
beemer2000 Posted March 5, 2006 Author Share Posted March 5, 2006 I installed a Vista Cruise on an RT a few years ago. It workded very good. You flipped your thumb down to turn it on and flipped it up to turn it off. While it was engaged you could still make throttle adjustments as needed. What could be simpler?? And easier to use?? With the heated grips this device supposedly cant't be intalled. Are any of the other divices available that are this user friendly? Doses anyone know about the Vista Cruise and it's ease of use? Has anyone adapted one to a heated grip?? Link to comment
