r77toy Posted November 25, 2015 Share Posted November 25, 2015 I've got a gas leak that looks like it's coming from the right side of the fuel distributor, how much of the ABS pump has to be removed to access the fuel distributor? Link to comment
roger 04 rt Posted November 25, 2015 Share Posted November 25, 2015 The ABS pump is all one unit. The book procedure for replacing the fuel distributor calls for lifting the frame to move the airbox out of the way. A mechanic who posts on ADVrider and UKGSer (steptoe) says he removes them by loosening the airbox, moving it backward, and fiddling the fuel distributor out the right hand side. Link to comment
Froggy Posted November 25, 2015 Share Posted November 25, 2015 Careful with those plastic pipes, once they kink you cannot straighten them. Good luck. Link to comment
