Roninfla1 Posted October 15, 2015 Share Posted October 15, 2015 Does any body know of the person in the UK that repairs Hall Sensors This is for a 2000 R1100RT Link to comment
The Rocketman Posted October 15, 2015 Share Posted October 15, 2015 GSAddict on BMWMOA in British Columbia. http://forums.bmwmoa.org/member.php?28598-GSAddict Link to comment
David13 Posted October 15, 2015 Share Posted October 15, 2015 I think BC is somewhat far from UK, isn't it? I'm sure there are others. The repair, as I understand it consists of rewiring it, as, if I understand correctly, which I may not, the usual problem is the wiring. Anyone with the wire could rewire it. I think it's a special wire, tho. But there should be someone in the UK. dc Link to comment
eddd Posted October 15, 2015 Share Posted October 15, 2015 Here is a link on how to repair the HES. Be sure to read the additional posts since they provide information that will make the job much easier. Link to comment
Michaelr11 Posted October 16, 2015 Share Posted October 16, 2015 GSAddict in Canada does an excellent job rewiring the HES. He charges $88 (USD) which includes the return postage. If you're really comfortable making critical connections and resoldering pins for a connector AND you can get the right high temperature wire, then sure do it yourself. Link to comment
