AnotherLee Posted July 25, 2015 Share Posted July 25, 2015 Since Roger mentioned using TPS voltage in tune ups, and since someone may have damaged his MCU during this measurement, maybe it would be good to know the best way to do this. This is what I use: [/img] [/img] Maybe you have a better way - how do you do it? Link to comment
JamesW Posted July 25, 2015 Share Posted July 25, 2015 Hi Lee, That's the way I do it as well. Link to comment
Crackenback Posted July 26, 2015 Share Posted July 26, 2015 I just used some sewing needles that I poked up through where the wires go through the little rubber seals. Pushed it just far enough to make contact with the little metal connectors at the end of the wire. Then I used a set of adapters that slip on the end of the test leads allowing the them to clamp on the needles. Got the needles from Walmart and the adapters from Radio Shack. Link to comment
