macx Posted July 17, 2015 Share Posted July 17, 2015 Did a search but came up with 1500 answers and didn't see anything headlight related in the first page or 2 I know where the left / right aiming knob is, but no amount of searching has turned up which way it should be turned to go one direction or the other. I know, sounds simple, try it and see. Tried it, didn't seem to make any apparent change even with a couple complete turns. What's up? Thanks Link to comment
dirtrider Posted July 17, 2015 Share Posted July 17, 2015 Morning Macx What are you working with? You are posting in the camhead forum but your profile shows you have R1200GT,& R1150R. Link to comment
macx Posted July 17, 2015 Author Share Posted July 17, 2015 sorry, that should read 2011 R1200RT Link to comment
dirtrider Posted July 17, 2015 Share Posted July 17, 2015 Did a search but came up with 1500 answers and didn't see anything headlight related in the first page or 2 I know where the left / right aiming knob is, but no amount of searching has turned up which way it should be turned to go one direction or the other. I know, sounds simple, try it and see. Tried it, didn't seem to make any apparent change even with a couple complete turns. What's up? Evening Macx Darn good question-- I have only adjusted a couple of those & for the life of me can't remember what way I turned it. You are adjusting the horizontal adjuster, correct? I believe (this reads as a SWAG) turning the adjuster to the right will pull the lower part of the R/H part of the lamp housing in therefore moving the emitted light bream right. You might have to start the engine (to induce shake), or pound on the light assembly with your hand to get the housing to move (that adjuster knob pulls on the light housing against a spring so the spring tension needs to push it back out). Link to comment
GordonB Posted July 18, 2015 Share Posted July 18, 2015 Quick tip, the stock oil filler cap removal tool that came with the bike is a perfect fit for adjusting those. Link to comment
blackyam Posted July 20, 2015 Share Posted July 20, 2015 Hi. Shooting in the dark ... not sure if this helps: http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=655585 ---John. Link to comment
