Bud Posted July 15, 2015 Share Posted July 15, 2015 By that I mean it is responding wrongly, when evens respond at all. Can not get to maps. Is it done for????????? Link to comment
kioolt Posted July 15, 2015 Share Posted July 15, 2015 Over on the Zumo forum you can information on replacing the touch screen with parts bought on eBay. If you don't want to do that you can pay Garmin to fix it. I believe they charge a flat rate of $150 not matter what is wrong. Link to comment
ltljohn Posted July 15, 2015 Share Posted July 15, 2015 Bud, look up Palm Dr.com. He fixed mine for a reasonable price. Link to comment
marcopolo Posted July 15, 2015 Share Posted July 15, 2015 Over on the Zumo forum you can information on replacing the touch screen with parts bought on eBay. If you don't want to do that you can pay Garmin to fix it. I believe they charge a flat rate of $150 not matter what is wrong. Garmin simply sends you a refurbished unit for that flat fee (as in it's not like you get your unit back). Link to comment
realshelby Posted July 15, 2015 Share Posted July 15, 2015 Garmin simply sends you a refurbished unit for that flat fee (as in it's not like you get your unit back). If you whine and complain about your expensive Zumo failing again, they will reduce the price to $100! I am on my 4th unit counting the original....... Link to comment
greiffster Posted July 15, 2015 Share Posted July 15, 2015 Garmin simply sends you a refurbished unit for that flat fee (as in it's not like you get your unit back). If you whine and complain about your expensive Zumo failing again, they will reduce the price to $100! I am on my 4th unit counting the original....... I thought (not confirmed) that Garmin had stopped repairing the 450/550 line. I believe it was $150. Link to comment
Bud Posted July 15, 2015 Author Share Posted July 15, 2015 Thanks for all the responses. Link to comment
APDDave Posted July 15, 2015 Share Posted July 15, 2015 Yes Garmin has stopped fixing and support for the 550. I have one that went out and called them about 6 months ago. I put the new screen in mine and that still did not fix it. Not sure if there are any other options out there to get it fixed. Link to comment
dirtrider Posted July 15, 2015 Share Posted July 15, 2015 Morning Bud Usually -not always though- weird screen actions on the Z-550 can be repaired by cleaning the edge of the screen (up under the case edge around the screen) An old 35mm film strip or even a thin cardboard usually works. The Z-550 has a touch screen of sorts so dirt (gunk) gets under the screen edge & puts a bind on the screen edge making it act weird. Otherwise you can buy a new (cheap) screen on E-Bay then replace your existing screen (pain to do but not brain surgery)-- Lots of how-to's on the Interweb. Link to comment
kioolt Posted July 15, 2015 Share Posted July 15, 2015 Yes Garmin has stopped fixing and support for the 550. I have one that went out and called them about 6 months ago. I put the new screen in mine and that still did not fix it. Not sure if there are any other options out there to get it fixed. I found this interesting since I have a non-functional 550 now. I checked and found you are right. Since I have an older 276C also I checked to see if it was still supported and found out that even though it is older then the 550 I can still get it repaired. Garmin states something like the 550 being old is the reason they are not supporting it yet they are still supporting my older 276C. I believe they just had so many touch screen problems and did not want to fix the problem permanently by doing some research on how. Link to comment
greiffster Posted July 15, 2015 Share Posted July 15, 2015 I believe they just had so many touch screen problems and did not want to fix the problem permanently by doing some research on how. Add button problems and you might be on to something. Link to comment
Bud Posted July 15, 2015 Author Share Posted July 15, 2015 Morning Bud Usually -not always though- weird screen actions on the Z-550 can be repaired by cleaning the edge of the screen (up under the case edge around the screen) An old 35mm film strip or even a thin cardboard usually works. The Z-550 has a touch screen of sorts so dirt (gunk) gets under the screen edge & puts a bind on the screen edge making it act weird. Otherwise you can buy a new (cheap) screen on E-Bay then replace your existing screen (pain to do but not brain surgery)-- Lots of how-to's on the Interweb. Looks like I will have to open it up. Link to comment
greiffster Posted July 15, 2015 Share Posted July 15, 2015 Looks like I will have to open it up. And while you're in there, you might want to inspect your 5 rubber buttons. Some of them are likely about to fall off. DAMHIK. You can use a little silicone around the buttons to help prevent loss. Link to comment
dirtrider Posted July 15, 2015 Share Posted July 15, 2015 Afternoon Bud You don't have to open it up to clean under the screen edge, just slide something thin & non scratching up into case along the screen perimeter. Link to comment
Bud Posted July 15, 2015 Author Share Posted July 15, 2015 Afternoon Bud You don't have to open it up to clean under the screen edge, just slide something thin & non scratching up into case along the screen perimeter. Thanks for the suggestion. Tried that, didn't help. Link to comment
Bud Posted July 15, 2015 Author Share Posted July 15, 2015 Looks like I will have to open it up. And while you're in there, you might want to inspect your 5 rubber buttons. Some of them are likely about to fall off. DAMHIK. You can use a little silicone around the buttons to help prevent loss. Thanks. My riding buddy has had all of his fall off! Link to comment
dirtrider Posted July 15, 2015 Share Posted July 15, 2015 Afternoon Bud You don't have to open it up to clean under the screen edge, just slide something thin & non scratching up into case along the screen perimeter. Tried that, didn't help. Afternoon Bud OK, then try a hard re-set and/or a battery removal & a hard re-set. If that doesn't work then--- Then put zumo 550 digitizer in E-Bay search & buy a new digitizer ($9.00- to about $50.00)--not that difficult to install. Just watch the delivery times as buying a digitizer from a foreign country can take some time getting here. (as far as I can tell they all seem to work about the same) Link to comment
dirtrider Posted July 15, 2015 Share Posted July 15, 2015 Looks like I will have to open it up. And while you're in there, you might want to inspect your 5 rubber buttons. Some of them are likely about to fall off. DAMHIK. You can use a little silicone around the buttons to help prevent loss. Thanks. My riding buddy has had all of his fall off! Afternoon Bud Those broken buttons can be repaired with a decent working not too bad looking repair. Just catch them before they get real bad & break a piece out of the case farther out than the button surround depression. I just cut the originals out using a very sharp EXacto knife-- then I use a rubber grommet & a reworked automotive plastic panel retaining Christmas tree. (homemade replacement buttons are actually easier to use with gloves on than the Zumo originals) Link to comment
greiffster Posted July 15, 2015 Share Posted July 15, 2015 I just cut the originals out using a very sharp EXacto knife-- then I use a rubber grommet & a reworked automotive plastic panel retaining Christmas tree. (homemade replacement buttons are actually easier to use with gloves on than the Zumo originals) Nice. I lost my + button and fabricated another out of a small rubber stopper from Lowes. I even stamped the + on it with a hot screwdriver. You can't even tell. Link to comment
marcopolo Posted July 15, 2015 Share Posted July 15, 2015 OK, I'm going out on a limb here, but why not just chuck the 550 and buy a new GPS? I suspect that you've gotten your money out of it. Link to comment
Bud Posted July 15, 2015 Author Share Posted July 15, 2015 OK, I'm going out on a limb here, but why not just chuck the 550 and buy a new GPS? I suspect that you've gotten your money out of it. Because the cheapest thing on a BMW is the nut that connects the seat to the handlebars. It's the same reason I just bought Foots 09 GS instead of buying a new one. My wife doesn't ride but has no problem with me riding. In fact, till last week, I had three bikes in the garage. Down to two Beemers now. the GS and a 99RT. Being married 48 years, I wouldn't feel right buying a new $25K bike from which she would get no enjoyment. Unlike Warren Buffett, my income isn't unlimited. Link to comment
marcopolo Posted July 16, 2015 Share Posted July 16, 2015 OK, I'm going out on a limb here, but why not just chuck the 550 and buy a new GPS? I suspect that you've gotten your money out of it. Because the cheapest thing on a BMW is the nut that connects the seat to the handlebars. It's the same reason I just bought Foots 09 GS instead of buying a new one. My wife doesn't ride but has no problem with me riding. In fact, till last week, I had three bikes in the garage. Down to two Beemers now. the GS and a 99RT. Being married 48 years, I wouldn't feel right buying a new $25K bike from which she would get no enjoyment. Unlike Warren Buffett, my income isn't unlimited. I hear you, but the price of a GPS is a far cry from the price of a bike. Whenever I buy any sort of consumer electronics, I immediately write its value down to zero. Good luck, no matter what you do. Link to comment
Bud Posted July 16, 2015 Author Share Posted July 16, 2015 I look at it like a flat tire on a motorcycle. Just because the tire is flat doesn't mean I need a new motorcycle. Penny saved, penny earned. But I've owned a lot of sailboats during the last 40 years because my wife's passion is sailing. So I know that friends have wondered a lot about about selling one and buying another. I never earned a penny on any of them. Link to comment
aggieengineer Posted July 19, 2015 Share Posted July 19, 2015 I've had the same problem on the 550 I bought in 2007. Twice. Both times, I've replaced the digitizer screen and brought the unit back to normal operation. I like the Zumo 550, so I keep a spare screen at the ready. Cheap insurance. Link to comment
John Ranalletta Posted July 19, 2015 Share Posted July 19, 2015 Over on the Zumo forum you can information on replacing the touch screen with parts bought on eBay. If you don't want to do that you can pay Garmin to fix it. I believe they charge a flat rate of $150 not matter what is wrong. Last year, Garmin told me they do not service 550s any longer. Bot a used unit from another member. Also, if your unit is TU and you have lifetime maps, you're SOL. The maps go with the unit, not the owner; so, you'll have to re-up for new maps, unless you buy a used unit with lifetime maps. Link to comment
