TREE Posted February 25, 2006 Share Posted February 25, 2006 Bike is a 1994 R1100RS . This is its first tear down since leaving the factory. I am doing a spline lube and new clutch plate. I was expecting some wear but this was a surprise. The rear splines were similar at both ends of the driveshaft. Maybe ' 94 was a good year. http://img62.imageshack.us/img62/1033/inputshaft20rj.jpg Link to comment
RFW Posted February 25, 2006 Share Posted February 25, 2006 Bike is a 1994 R1100RS . This is its first tear down since leaving the factory. I am doing a spline lube and new clutch plate. I was expecting some wear but this was a surprise. The rear splines were similar at both ends of the driveshaft. Maybe ' 94 was a good year. Looks like my K100RT that has ~200,000km on it. Make sure you use the RIGHT grease! You need a high moly content grease. The stuff that is used for front wheel drive car U-joints is good. Also, Honda sells a 60% MoS2 grease used for the splines in their Gold Wings, and it works well (I use it myself). Whatever you do, NEVER use ordinary non-moly grease! You need an extreme pressure Moly grease, which is the only thing that will protect against "fretting" wear. Bob. Link to comment
bmwmick Posted February 25, 2006 Share Posted February 25, 2006 Tree, Those look 'beautiful'. I don't even see any 'impact' marks from heavy throttle usage. I'd say lightly lube the new clutch hub with some Honda Moly-60 and you're good for another 100K. Mick Link to comment
peterbulgar Posted February 25, 2006 Share Posted February 25, 2006 That is what all splines should look like at 60K miles. peter '73 R75/5, '04 R1150RA Link to comment
Tom P Posted February 25, 2006 Share Posted February 25, 2006 Nice to hear about the success stories too! Thanks for the post Link to comment
bmweerman Posted February 26, 2006 Share Posted February 26, 2006 Those are freakin' beautiful!! As others have said...thanks for the success story!! Cameron Link to comment
