Shane J. Posted June 29, 2015 Share Posted June 29, 2015 My wife's bike when cold,the starter make's a light grinding noise when the starter button is released. Doesn't always do it and seldom when warm. Bike starts fine. Any advice? Link to comment
mneblett Posted June 29, 2015 Share Posted June 29, 2015 Sounds like the starter's bendix is not pulling the starter gear back out of engagement quickly smoothly. Not uncommon; typically just accumulated dirt. Requires nothing more than pulling the starter out, removing the nose cone and cleaning/lubricating the mechanism. I did the same thing a couple months ago on my son's R100 and the release noise was gone. Link to comment
waynerd Posted June 29, 2015 Share Posted June 29, 2015 As Mark mentions, this is a common condition and relatively easy fix. THIS DOCUMENT comes from the "M/C FAQ" page (tab in the top banner) in the "BMW R11xx Sticking Starter Service" sticky. It'll walk you through the procedure with picture goodness. Link to comment
greiffster Posted June 29, 2015 Share Posted June 29, 2015 In addition to the cleaning, I find that gently stretching out the solenoid spring is helpful. I think it gets a little soft over time and a bit of extra spring compression helps on release of the starter button. Link to comment
Skywagon Posted June 29, 2015 Share Posted June 29, 2015 Go here....easy fix... http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=816545&page=1 Link to comment
Shane J. Posted July 2, 2015 Author Share Posted July 2, 2015 Thank you, that worked. Link to comment
RPG Posted July 13, 2015 Share Posted July 13, 2015 Used the same process for cleaning/lubing mine last Friday night. Got it done in less than an hour. 2nd time around for this job on my 72k 2004 RT. Sounds like new again. RPG Link to comment
