bruce1045 Posted June 22, 2015 Share Posted June 22, 2015 2004 1150rt My windsheild wont go up, no noise from motor or clicks sounds. I have tried maually moving it, no haven't used a hammer yet!! Done some research and looks like I need some new relays, or relays have bad connections. Since I have to take nose piece off to access relays, plan to get new relays either way. I can't seem to locate the relays on microfiche. or part numbers I found windsheild parts etc, on microfiche but not relays, if anyone could help would be greatly apprciate it. Btw, AS cycles has 15% off fathers day sale ends today at midnight http://www.ascycles.com/ thanks Link to comment
dirtrider Posted June 22, 2015 Share Posted June 22, 2015 Evening bruce1045 My parts book shows -- 0161361393415 MINIRELAY, CHANGE-OVER CONTACT, GREY (it uses 2 relays). Are you sure you need a relay (or relays). Check fuse # 3 & fuse #9 first. There is a (raise) relay & a (lower) relay but the (lower) relay is used for the low (ground) side path on the raise cycle & the (raise) relay is used for the low (ground) side path on the (lower) cycle. Link to comment
bruce1045 Posted June 22, 2015 Author Share Posted June 22, 2015 No not sure at all, but most of the research I've done, points to relays. I will double check those fuses first, Thanks for finding those part numbers. Open for suggestions, besides banging it with a hammer Link to comment
dirtrider Posted June 22, 2015 Share Posted June 22, 2015 Open for suggestions, besides banging it with a hammer Evening bruce1045 Personally before I started replacing relays I would verify both 12v power (ign switched & battery 12v) as well as chassis ground it present at the relays. If power & ground OK then verify up/down switch is working. Then I would manually jump relay terminals to eliminate, or point-to, a bad relay. At relays verify red/white wire has full time 12v B+__green/blue wire at switch is getting ign-on 12v__that brown wire at both relays has continuity to ground__ gray/yellow wire at relay gets 12v when up button is pushed (key-on)__blue/yellow at relay has 12v when down button is pushed (key-on) Link to comment
Jim Moore Posted June 22, 2015 Share Posted June 22, 2015 that happened to me a long time ago on my RT. The shop didn't have a relay handy, so they jumped the holes to put the windshield up (the position I wanted) while they waited for the relay to come in. I never looked into how they did it, but I'm sure it wasn't too hard. Link to comment
Andre1150 Posted June 23, 2015 Share Posted June 23, 2015 When that happened to me, I just bought a working motor/relay/great unit on ebay. It might be the relays, might be the motor, or in my case, a snapped plastic gear. Either way, it was worth the time/expense to find a backup. Link to comment
TEDZ Posted June 23, 2015 Share Posted June 23, 2015 Mine failed to work a few years ago and a cleaning of the terminals of the relay fixed it. Link to comment
