mark1234 Posted June 20, 2015 Share Posted June 20, 2015 I have in my possession a2003 1150rt that was sitting for 2 years without being started. What should I do before I Turn the Key? I Don't want to cause more problems with it and I know the Gas must be bad. I know how to pull the Gas tank but do I need to do anything else with the fuel injectors, etc. to aid in my success? Any Help would be a blessing Link to comment
dirtrider Posted June 20, 2015 Share Posted June 20, 2015 I have in my possession a2003 1150rt that was sitting for 2 years without being started. What should I do before I Turn the Key? I Don't want to cause more problems with it and I know the Gas must be bad. I know how to pull the Gas tank but do I need to do anything else with the fuel injectors, etc. to aid in my success? Morning Mark Depends on how bad the gasoline is & how far into the system it has degraded into varnish. Personally I would start by opening the fuel tank cap & simply sniffing. If the gasoline smells skunky then you know what you are dealing with. Next, remove the tank & completely drain it then flush it out. (if it was skunky inside keep cleaning/flushing until it is decent smelling & varnish free inside. If gunk found or really bad smelling inside then also replace the in tank fuel filter NOW. (see hose & filter replacement below) Then put tank back on & put a couple of gallons of fresh gasoline in the tank, also put some Techron concentrate in the tank. Next, remove fuse #5 for about 30 seconds then do a new TPS re-learn (it's in your riders manual under battery install) Now see if it will start & idle, if so then allow to run for a while (caution don't run at fast idle or idle for long periods without putting a couple of fans blowing on front of engine) If it starts good & idles decently then a good chance your fuel injectors are probably OK . Now the important part-- before putting it back together & especially before venturing far from home I would recommend that you install a new in-tank fuel filter & replace all the tank internal hoses. Those in-tank hoses (especially the U shaped high pressure hose are notorious for rupturing on older BMW 1100/1150's & leaving you stranded. Look in the archives here (use search function) & you will find LOTS of cases of in-tank fuel hose issues. Link to comment
roger 04 rt Posted June 20, 2015 Share Posted June 20, 2015 +1 to all DR's comments. And while you're servicing the tank hoses make certain, if you have a charcoal canister in the tank vent, that the hoses inside and outside the tank are routed correctly and that air passes through that system easily. Link to comment
mark1234 Posted June 20, 2015 Author Share Posted June 20, 2015 Thanks for your replies. Your Help will give me the confidence to get it back on the road and running. Link to comment
