Trobinson Posted June 12, 2015 Share Posted June 12, 2015 Forgive me if I'm asking a dumb question, but I noticed the pistins have cutouts for the valves. Are they enough to keep the valves from hitting the pistons? Link to comment
dirtrider Posted June 12, 2015 Share Posted June 12, 2015 Afternoon Tom Depends!-- Obviously they keep the valves from hitting with the cams timed correctly & the engine RPM's under valve float. But they are not deep enough to keep the valves from hitting the pistons if the valves float or the cams go out of time. Link to comment
lkchris Posted June 12, 2015 Share Posted June 12, 2015 They have timing chains, not belts. Link to comment
mneblett Posted June 12, 2015 Share Posted June 12, 2015 But they are not deep enough to keep the valves from hitting the pistons if the valves float or the cams go out of time. Which means it is an interference engine. Link to comment
Trobinson Posted June 13, 2015 Author Share Posted June 13, 2015 That's the answer I was interested in. I couldn't recall the correct term. Link to comment
