Jim Moore Posted June 9, 2015 Share Posted June 9, 2015 Hi Guys, My new-to-me 94 R1100RS with the new engine has been running great! Well, kinda great. The fueling is not perfect. It doesn't surge, but throttle on / off transitions are a little rough, and it hunts a little at intermediate throttle settings. It is difficult to be precise on corner entry, and it's hard to make small mid-corner corrections. (As a note, the spark plugs are new, valves are adjusted, and the TBs are within 1" of ATF of each other.) On a lark I tried pulling the CCP today. I have to say it has turned it into a different motorcycle. On and off throttle transitions are perfectly smooth. I'm able to make tiny mid corner corrections with no drama at all. I can rail through a 270 degree onramp at 6500 rpm without a bit of hunting. Even cruising around the neighborhood is a more pleasant experience. I cannot overemphasize how much this little trick has improved my motorcycle. I strongly urge everyone to try it. For 1100 owners, it takes two minutes. Open fusebox. Remove CCP. Ride. It's a bit more involved for an 1150 owner. You have to unplug the O2 sensor under the tank. It's still worth it. Give it a try. The difference is amazing. Link to comment
roger 04 rt Posted June 9, 2015 Share Posted June 9, 2015 Jim, Pulling the coding plug and disconnecting the O2 sensor on an R1150 or R1100S, doesn't have the same effect as the R1100R/RT/GS. Pulling the plug on your R1100 though makes a small gain in fueling as long as you are running non-ethanol fuel. If you use E10 the gains evaporate. What plug did your bike come with, Yellow or Pink? I ask because a beige plug, which is also Open Loop like No Plug, may be a better match. Link to comment
Jim Moore Posted June 9, 2015 Author Share Posted June 9, 2015 HI Roger, On my R1150 pulling the CCP did nothing, but disconnecting the O2 sensor was like a miracle cure. It felt like the same thing as pulling the CCP on an 1100. I've read that the R1150 computer uses the O2 input whether or not a CCP is installed. The R1100 computer does not use the O2 input if the CCP is pulled. I kinda figured the key was the O2 sensor inputs. That could be internet malarky, but it sure fit my experiences. My new-to-me bike has a yellow plug. Link to comment
roger 04 rt Posted June 9, 2015 Share Posted June 9, 2015 On a slightly different note ... Since you found that the extra fuel from the R1100's no O2 sensor map is to your liking, there's a good way to be able to dial up the fuel to where your bike will really growl. Shift lambda down to 0.90 - 0.94. Give Beige 30-87a a try. Link to comment
