Twisties Posted June 2, 2015 Share Posted June 2, 2015 I'm used to dropping the FD for the gear oil change (Remove exhaust, remove wheel, remove speed sensor, remove brake caliper, remove upper link pin). That only leaves the lower attachment point to worry about. Never been in that thing. The old rep rom I have has nothing to say about this that I can see. There is a list of torques, but I'm not even sure which is for what. Anyone got a link to a pictorial or video? Link to comment
CoarsegoldKid Posted June 3, 2015 Share Posted June 3, 2015 I had to remove my FD to fit it on the replacement swingarm. That attachment is on tight. I don't recall that it had thread locker on either. I needed two large lever arms to break it loose. My guess is the larger torque spec is the one for that one. Link to comment
Twisties Posted June 10, 2015 Author Share Posted June 10, 2015 Looks like the lower attachment point is 100 nm (73 lbs ft) with blue loctite. The upper one is 43 nm (31 lbs ft) Looks like I'll be doing it shortly. The FD just arrived. I take it the cover on the lower point just pops off with a screw driver or such. Link to comment
